Are headers really that hard?
Old Jun 19, 2005 | 07:56 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I was changing the oil yesterday and I looked up at one point and saw the manifolds and I thought, at least the driver side, that doesn't look to hard to change out.
Is the passenger side worse looking?
I mean, remove the Y-pipe, remove the plugs, and the bolts then drop out and wiggle the header back up in there. Am I missing something? I'm thinking I am, but damn. I want to ask for headers again for my Bday next month.
Old Jun 19, 2005 | 08:06 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Its not the slightest bit hard, its just time consuming. Removing accessories and fighting rusted bolts takes a while.
Old Jun 19, 2005 | 10:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The headers I installed (Hedman 68470) were shorty headers, but it was SOOOOOO much easier than the nightmare installations people desribe here. They were in the car, bolted on, and ready to have the Y-pipe bolted on in 1/2 an hour. The only thing I had to do to make them slide in was remove the drivers side valve cover. I didn't even have to remove the spark plugs!
Header installs, IMO, are way over-rated as being rediculously difficult. That goes for shorties only though, I've never installed a set of long tubes on these cars, but it looks a good bit more difficult to do.
Old Jun 19, 2005 | 11:24 PM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
The nightmare installs are probably more frustration than anything else getting in the way of the people completing the job. To do emissions legal headers are a PITA in these cars just because of the amount of time and contoryions you need to make.
Old Jun 20, 2005 | 04:20 PM
Car: 1994 Trans Am
Will cars pass emissions with AIR removed? Or is it just visual?
I'm might be doing Long Tubes, so they are harder?
Old Jun 20, 2005 | 04:36 PM
Car: 86 T/A
Engine: HSR 355
MA is fairly strict when it comes to emissions (not like CA but its up there), and my car passed visual and emissions with the air tubes clearly cut and clamped shut from the previous owner. Hedman long tubes were extremely easy to fit in my car, no cutting or grinding.
Old Jun 20, 2005 | 04:45 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i installed Hooker 2055's with AIR tubes.
the only bastard part of the deal was breaking loose the stock manifold bolts..
and on installation, the passenger rear bolt is almost impossible to tighten with out removing the A/C box.. now i have A/C delete and its a dream.
when you do install a set of headers.. key trick i learned was put the rear and front bolts in half way with your fingers 1st... then put in the middle bolts. dont use the crappy gaskets they give you..
ive had success with Mr. Gaskets exhaust gaskets.
dont forget to check/retighten the header bolts after you drive around the 1st week, they tend to work themselves loose.
Old Jun 20, 2005 | 06:27 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I bought the hooker 2055 headers, and they came with the gaskets...wouldn't the manufacturer's gasket be the proper one to use?
Old Jun 20, 2005 | 06:30 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Tell us that 2 months after they blow Honestly I'd go buy some better ones, but its up to you.
Old Jun 20, 2005 | 06:47 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
not necessarily.. they usually give you some low quality paper gaskets that they get for .3 cents each and just toss them in the box so people dont complain about not getting gaskets. take a look at them and you will see they are really low quality.
i have had 5 cars, and all 5 i have used aftermarket headers.. and none of the gaskets that came with them have ever been any good at all..
ive used Gibsons(for my Tahoe and Suburban)
Flowtech for my old 86 IROC
Hooker for my 92
and JBA for my 95 Z28
all came with crappy gaskets..
Old Jul 29, 2006 | 09:16 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
headers for 88 IROC
I've got the "Y" pipe, driver's side manifold, and all but the farthest 2 bolts on the passenger side off. I removed most of the A/C and put in the delete pulley last month. Do I need to remove the stock A/C box to get to the last 2 bolts? The tabs on the stock bolts that keep the nut from backing out are a real pain! So far I haven't broke any bolts off. I have also got the plugs, wires, cap/rotor, and o2 sensor to replace. Should I use the heat shields even though the new headers are ceramic coated? Am I going to need to get new nut retainers? Should I get new hardware? Thanks for any responses, Daniel U
Also, will I be able to drive a short distance with out a muffler (to weld up the y pipe to the existing exhaust) without doing any damage(running to lean)to the motor?
Old Jul 29, 2006 | 09:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
Old Jul 29, 2006 | 09:46 PM
Car: 1994 Trans Am
Looks like my post was dug up from the grave. This thread is over a year old. I got my headers in March. Install was easy as hell.
Old Jul 29, 2006 | 09:47 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Mine have been holding up for 3 years so far.
Old Jul 29, 2006 | 10:44 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Originally Posted by Fast68
if you do put headers on and i assume you have a 305 or 350 then i want ot buy the original y pipe off you i am still looking for one for my 82 t/a project
if you would mail it in cardboard wrap
lemme know
Are you interested in my stock y pipe? If you pay shipping from 93446 in CA. it's yours. It's a 5.7 L98 with TPI if that matters.
Do you have A/C though?
What type of gaskets did you use?
Old Jul 29, 2006 | 10:59 PM
Car: 1988 IROC-Z
Engine: 427 SBC
The ones that came with the headers.
Old Jul 29, 2006 | 11:05 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Should I go with Fel-pro? Mine didn't come with any.
Old Jul 29, 2006 | 11:11 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
commifornia ?
damn well that wont work then
figures.........
hum
thanks
exh manifold gaskets work the best and dont blow out
its all i ever use on headers
real simple
good luck
Last edited by Randy82WS7; Jul 29, 2006 at 11:13 PM. Reason: Automerged Doublepost
Old Jul 29, 2006 | 11:20 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
I'll take that into consideration. Never thought of stock exh man gaskets on headers. huh?
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
Accerrito22
Sep 5, 2015 09:34 PM
willyjoejr
Sep 3, 2015 09:26 AM
