Why doesnt my exhaust fit?
Old Jun 22, 2005 | 09:49 PM
sellmanb's Avatar
Car: '86 Berlinetta
so I've got a big problem. Either my Cat-back isnt right, the direct fit cat isnt right, or the y-pipe/headers arent right... which nail it down to ... just about anything in the exhaust lol.
basically, the exhaust is hooked up like the picture below.
I have the same cat-back (it's a hooker catback) as pictured. Then a direct-fit catco high flow cat, and SLP 1 5/8" headers/y-pipe which were fine on the car they were on before.
I'm confused why all these "direct fit" parts arent fitting directly!
Old Jun 22, 2005 | 11:06 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i had a set of slp headers and i had fitment problems with the headers hitting the oil pan (moroso pan) i sold them off and went with a set of edelbrook headers. i did notice that the y pipes were different. maybe its a problem with that. also how long is the cat measuring. is it the same size as the stock cat.
Old Jun 23, 2005 | 07:07 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
"Bolt on's never are"
Exhaust can be the trickiest bolt on because of all the variables......way to many factors to consider....just figure out a way to make it fit.
Old Jun 23, 2005 | 11:12 AM
sellmanb's Avatar
Car: '86 Berlinetta
The only thing I can think of is using this flex tube, and cut out part of the cat-back so it's more of a straight shot for the tube.... I just dont know how well flex tubing would hold up against exhaust heat.
Old Jun 23, 2005 | 11:41 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've been using it after the collectors on the '57 since '99, and behind the converter on the full-size van since '00.
Old Jun 23, 2005 | 05:16 PM
sellmanb's Avatar
Car: '86 Berlinetta
Good to know, thanks for that info Five7
Old Jun 24, 2005 | 07:28 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
that pipe looks way off for some reason......well i hope you can make it fit and let us know how'd you do it ....heres a pic of my y-pipe to compare that to ..hope it helps
Old Jun 24, 2005 | 11:03 PM
sellmanb's Avatar
Car: '86 Berlinetta
That helps a ton actually! Thanks for the picture, I hope you dont mind my editting it to show how mine is.
I'm assuming this is an exhaust setup for a earlier model Camaro that I have?
The red line is how mine goes.... btw, do you know if they sell just the y-pipes?
Old Jun 25, 2005 | 03:42 PM
rudyt5000's Avatar
aint no problem bout editing my pic....cause i also edited yours....well i figured that these cars have the exhaust running along the driveshaft ....and your cat-back is not lettin it run side by side with the driveshaft...maybe you can bend it yourself or have a muffler shop bend it just a bit ....but since you said your y-pipe is pointing differently...then you may try bending that too like in my pics of my y-pipe . Your car is a 86 Camaro right? well here's a pic of what i would do
Old Jun 26, 2005 | 06:26 PM
sellmanb's Avatar
Car: '86 Berlinetta
I actually found out why it all doesnt fit up... SLP trying to be money hungry, and didnt make it a direct fit with a cat ... UNLESS you buy their conveniently made "catalyst adapter" as you can find on Spohn's website, http://www.spohn.net/product.cfm?productid=1442 is the link directly to the item in mention...
Thanks for the help everyone.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
timonator
Aug 11, 2015 09:56 PM
