need help choosing headers
Old Aug 19, 2005 | 10:06 AM
  #201
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Opps forgot about the air tubes, never had that crap on my car(of course now my inspection sticker is about a year and half out). By bad, but my headers do look bitchin, well at least compared to the flowtechs anyway, here is a pic with the flowtechs
Old Aug 19, 2005 | 10:09 AM
  #202
BT283's Avatar
Originally posted by kalel21
Here's another pic of the whole setup going in and the 3 inch electric cut off.
NICE SETUP
Old Aug 19, 2005 | 12:03 PM
  #203
kalel21's Avatar
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
Thanks!
It should go in nice with the Hotchkis TVS System I just got. I posted some pics on the suspension board.
Old Aug 19, 2005 | 02:12 PM
  #204
DanTheMan_smlk's Avatar
wow...i just drove the camaro for the first time with open headers. You can feel the car in your chest, it makes your whole body shake. It was so loud...i drove around my neighborhood and some lady mowing her lawn stopped and put her arms at her side with a dirty look on her face. HAHA!!!
Old Aug 19, 2005 | 02:25 PM
  #205
BT283's Avatar
I just cranked my car up, and it has a completly different tone than with the Flowtech (until it ran out of gas..haha) but the flowtechs where covering up my ports though
Old Aug 19, 2005 | 03:22 PM
  #206
BT283's Avatar
Oh yea DanTheMan is you Ti-Tech coating still there, just wondering if it is a good coating or not
Old Aug 19, 2005 | 03:32 PM
  #207
yes its still there......wtf its titanium
Old Aug 19, 2005 | 03:38 PM
  #208
BT283's Avatar
dont have a hissy fit just wondering i didnt know it was titaniaum
Old Aug 19, 2005 | 03:43 PM
  #209
im not mad at all
Old Sep 2, 2005 | 05:46 PM
  #210
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
WOW I just read three weeks worth of header install... lol. Should have listened to them man. Anyways atleast you're done. Got any pics?
Old Sep 3, 2005 | 02:48 PM
  #211
i didnt want to tilt my engine cause its bad for the tranny
yes i have pics.....what exactly do u want pics of?
Old Sep 3, 2005 | 03:13 PM
  #212
BT283's Avatar
How is tilting your engine like 2 inches going to hurt your tranny, that is not true DantheMan
Old Sep 3, 2005 | 03:36 PM
  #213
oh well i maganed to get them in there without doing it and i wasnt in a rush so its ok
Old Sep 3, 2005 | 03:37 PM
  #214
BT283's Avatar
Old Sep 4, 2005 | 09:36 PM
  #215
Engine: carbed 383
I was just wondering if you had any pics of the headers on the car with the ti-tech coating to see how its holding up.
Old Sep 4, 2005 | 10:33 PM
  #216
its holding up fine, no rust. This is after 200 miles
Old Sep 4, 2005 | 11:17 PM
  #217
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
One thing that will save you a ton of money at the pump is to ditch those one way valves and get pipe caps They allow lots of air to come into the exhaust and make the O2 see a false lean condition.
Also, what I like to do is to run wire looms on the valve covers and drop the wires down behind the air tubes. I also use a section of split silicone shething from one of the old wires to protect the spark plug wire where the AIR tubes contact it. Heres a pic. Not the best one to show this but it gives you the general idea. Leaving the wires up around the primaries with all the heat will damage the silicone sheathing after awhile if they come in close contact.
Old Sep 5, 2005 | 04:42 PM
  #218
what kind of pipe caps...where, what brand
Old Sep 5, 2005 | 05:45 PM
  #219
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Originally posted by Lo-tec
Put your old check valves back on, and then buy a box of rubber caps at autozone. They are made by HELP and come with 4 or 5 different sizes in one box (two of each size in the box). I think you need 5/8" ones.
Old Sep 5, 2005 | 06:00 PM
  #220
Car: 88 Camaro SC
Engine: SFI'd 350
You can also use the brass caps. IIRC, theyre 1/2" NPT pipe caps. Any hardware store should have them.
Old Sep 5, 2005 | 07:24 PM
  #221
what does iirc mean? People say that all the time on these boards...ive never heard it anywhere else..
Old Sep 5, 2005 | 11:38 PM
  #222
Engine: carbed 383
i think it means if i recall correctly
Old Sep 6, 2005 | 05:32 PM
  #223
oh...thats kinda lame....
lol
Old Sep 14, 2005 | 03:32 PM
  #224
i like gooooooooold (actually its just brass but oh well...)
i got these brass 1/2 inch "pipe" cap from ACE hardware and they fit perfectly..no more one-way valve leak
and just for fun (lol, you can see the oid AIR tube on the right)
Old Sep 14, 2005 | 03:50 PM
  #225
BT283's Avatar
Get a sound clip yet?
Old Sep 14, 2005 | 03:57 PM
  #226
damnit....now i feel bad cause i dont have a sound clip
i cant afford a sound recorder
Old Sep 17, 2005 | 11:10 PM
  #227
btw, the pipe plugs are doing great, no oxidation yet
Old Oct 24, 2005 | 09:02 PM
  #228
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've never seen a thirdgen with the oil fill cap in the front like that.. Weird.
-- Joe
Old Oct 25, 2005 | 01:40 AM
  #229
Car: 88 Camaro SC
Engine: SFI'd 350
My guess is that he just put it on backwards, not that it really matters that much.
Old Oct 25, 2005 | 05:57 AM
  #230
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well then the lip will be on the inside, which could potentially contact the manifold and warp the ridge of the valve cover.
They only go on one way..
-- Joe
Old Oct 25, 2005 | 07:24 AM
  #231
Car: 88 Camaro SC
Engine: SFI'd 350
IIRC, the ones on my LO3, with the exception of the breather and such, where symetrical. It may vary. Ill have to check later.
Old Oct 25, 2005 | 09:12 AM
  #232
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
whats better Shorty Headers or Long tube?
Old Oct 25, 2005 | 12:55 PM
  #233
Car: 88 Camaro SC
Engine: SFI'd 350
3rd gen shorties are easier to install and are a direct bolt on, if you want to call it that. Long tubes will require a custom y-pipe and othe items to get them in.
Old Oct 25, 2005 | 01:00 PM
  #234
Car: 88 Camaro SC
Engine: SFI'd 350
-- Joe
I checked mine. The ones I have are omnidirectional. Mustve revised some of the valve covers for different years.
On a side note, thankfully they are. I swapped the drivers and pass. side valve covers so they would fit and not be obstructed by the stuff over top of them.
Old Oct 25, 2005 | 05:49 PM
  #235
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Weird. Normallyt he ridge is machined flat on the inside as to not obstruct the manifold.
-- Joe
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Chad Speier
Sep 24, 2015 12:32 PM
