Anyone running a single 3" Bullet?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
If so, how loud is it? I have Headman shorty headers, y pipe, catco 3" cat, 3" cat back with genaric muffler with dual 2 1/2" tailpipes.
I am wanting to ditch this crappy turbo type muffler, and go with a single 3" in and out performance muffler.
I was thinking about the bullets because they are sooo cheap, or a Hooker Aero Chamber, because I have heard they flow real well.
Will I be able to live with a bullet, or will I just get harassed, or driven insane?
Transmission: 4L80E/4L80E
Re: Anyone running a single 3" Bullet?
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
with a cat it's not really all that loud. Without the cat it's much louder though.
I have straight pipes with a bullet and love it.. all depends on if loud noises bother you. If they do, by a flowmaster. If they don't, get a bullet muffler.
You may or may not get harassed. I get compliments.
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Which bullet are you ordering? I should have my Dynomax (p/n 24222) on Friday. For $35 I couldnt pass it up.
The exhaust on my car is the same as yours. Hedman shorties, 3" y-pipe into a direct fit 3" in/out catco cat with a full 3" cat back.
My plan is to remove my 3" flow and test fit it right there. I'll post a clip of what it sounds like over the weekend. If I like then I am going to have the full loudmouth system made at a place nearby.
I also heard the hooker sounds really good as well. You probably cant go wrong either way.
Car: 1971 Camaro
Engine: 427
Cool, glad to hear someone else is doing it to. I would like to hear your results. I am looking at the 12" bullet. It will be a couple weeks before i get mine though.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
My car had a 3" bullet. I found it intolerably loud. I'm sure my neighbors didn't care for it either.
Car: 1971 Camaro
Engine: 427
The one you got tyhe 12" or the 18".? After looking under it last night, the 16" seems like it would fit better, plus maybe be a little quieter than the 12"?
Car: '72 Chevy Nova
Transmission: TH350
Fast_25th,
Got that bullet on?
Fast_25th,
Got that bullet on?
Car: 1971 Camaro
Engine: 427
I heard it, sounded a bit cackley ( is that a word?) But I noticed you are not running a cxat, so I am guessing mine will sound a little smoother.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Bullets ain't for me. I would much rather have a quiet car with good tone. Hence my SLP 2otL cat-back. Nice'n quiet most of the time. Cops tend to harass loud cars around here. I also get annoyed with highway drone which is why I don't have a flowmaster on the car anymore either.
Car: '72 Chevy Nova
Transmission: TH350
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
question.....
i am also thinking of a single 3inch bullet to get rid of my flowmaster
summit has a 16 incher and a 23.5incher. i am thinking 23.5 as it will be somewhat quieter. would that be correct? i am still running a cat. how loud do you think that would be?
Car: 1971 Camaro
Engine: 427
I would think the longe one would be a little quieter, but I doubt you can tell much difference. I will be ordering the longer one.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
This is funny I did this exhaust over a year ago, I have edelbrock tes's with 3" collector, with a long 18" bullet and a dump before the axle, sounded amazing, its still plenty loud, but mellow up to 2500, then it starts to get much louder, but cruising at 80 isn't bad and the good part about using them, is that they have 0 backpressure and act like a collector extension, its a more economical muffler too. I did my exhaust this way, b/c it will support 450hp, without hurting hp, and boosting torque, along with a different, better sound in my opinion contrary to ordianry belief. And I was tired of flowmaster this, flowmaster that, I would buy an edelbrock before hooker, flowmaster or most other brands, because the cost for the sound, wasn't worth it to me, considering that I would make the same hp as the more expensive exhaust. Not to mention like others have said, some people may not like it, but I love it and its even better when mash the gas, and the world sounds like its coming to an end, next to and behind the car while the car next to you drifts ever so far away.
The shorter mufflers are definitely louder and these mufflers work amazing, these are commonly used on 8.90 dial in, throttle stop classes and faster, like low 7's faster, they can't blow out either. These are older pictures, I have a dump that is about 12" long now that dumps in the middle of the car.
Car: '72 Chevy Nova
Transmission: TH350
Yes, the longer one will quiet it down more than the shorter one, as well as give it more "tone."
Car: '72 Chevy Nova
Transmission: TH350
MUCH louder. I had a flowmaster 80 on my T/A before the bullet, the difference is a LOT. Sounded pretty much the same at idle, but after that it just blew the flowmaster away.
Car: '72 Chevy Nova
Transmission: TH350
If you're looking to retain the flowmaster, but have something a little more nuts intended for fun use, you need a cutout!
You can get a manual one for $30 from summit racing, and have it installed. You have to crawl under there and undo the plate on it to allow the exhaust to flow through it instead of the cat+muffler.
Or you can get an electric one (about $200) which you can open with a switch in the cockpit.
A cutout basically is a valve installed in your exhaust system that when open lets your exhaust flow straight through and bypass everything past it.
Car: 89 Iroc-z
Transmission: TH400
well i am waiting for my bullet to come in and soon as i get my car back i will put it on.
urban, would you say that the bullet is excessively loud? as loud as open pipe? and did you have a cat on?
