Quiet power
Old Sep 1, 2005 | 11:10 PM
tad1214's Avatar
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
Quiet power
I did a search on this and didnt see anythingso forgive me if this has already been asked. I am looking for a quiet muffler that will still have excellent flow properties. I like to be able for speak in/around the car no problem but want the high flow of a performance muffler. Will be running a 383 with second biggest ZCam (Hyd. flat tappet) 2 1/2" dual figured would be a proper size, running a 2 1/4" dual right now from dynomax and boy does it suck. Just dont want to be the obnoxious car going down the street but when i get down i want the power still there.
Old Sep 1, 2005 | 11:23 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I have always read dynomax systems perform well and are one of the quieter systems.
Old Sep 2, 2005 | 11:28 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If I was you, I'd pick up a very quiet system, like maybe Flowmaster 30s or something. Those are extremely quiet, barely louder than stock.
Then weld an electric cut-out on there
Old Sep 2, 2005 | 11:08 PM
tad1214's Avatar
Car: 1983 T/A
The dynomax system exits out the same side in the rear (looks like single exhaust with dual tip muffler almost.) and it fits really bad.
Old Sep 3, 2005 | 12:46 AM
57TUNED's Avatar
Car: 88 iroc
muffler
i had good luck with a company called straightline performance muffler. they sound like a quiet slp muffler.
Old Sep 3, 2005 | 08:31 AM
tad1214's Avatar
Car: 1983 T/A
urbanhunter44 If I was you, I'd pick up a very quiet system, like maybe Flowmaster 30s or something. Those are extremely quiet, barely louder than stock.
Good call! That sounds nice, where should I mount the cut out, just infront of the mufflers or right off the headers? Who makes 2 1/2" cutouts?
Old Sep 3, 2005 | 09:49 AM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
When i first built my car i put a 2 3/4 inlet and outlet muffler off of a stock SS, I think it was a SLP muffler but im not sure. It was really quiet but still had plenty of power, in fact when i went to the Flowmaster 80 series i felt no difference at all.
Old Sep 3, 2005 | 03:15 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'd put single 3" exhaust on it with a Dynomax Ultra-Flo muffler and a cut-out. Reasonably quiet, good ground clearance, and it'll be fine for your average 11-12 sec street/strip kinda car.
Old Sep 3, 2005 | 03:47 PM
Car: '72 Chevy Nova
Transmission: TH350
I'd mount them directly off the headers, probably right after the collectors. The closer they are to the headers, the more power you're going to have.
Lots of companies make them, do a search on summitracing.com and pick which ones you like.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
