copper header gaskets
Old Sep 6, 2005 | 12:03 AM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
does anyone know which way a set of copper gaskets should be installed?one side has raised edges,and the other side is indented,if your looking at the raised side is that how they are slid in?with the raised side of the gasket facing out,i never used these before and dont know which side faces out when sliding them down in between the header flange and exhaust ports,does any one know which side faces out the raised or the indented side? this sucks not knowing for sure,iam guessing the side with the markings on them should face out right?they are stamped with part# on raised side,but not sure
Old Sep 6, 2005 | 09:56 AM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
Usually the gaskets themselves will say on them "this side out", but on my SCE gaskets the raised section is out touching the header flange.
- Joel
Old Sep 6, 2005 | 10:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
flat side to head, embossed side to header.
Old Sep 6, 2005 | 10:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What he said.
Old Sep 6, 2005 | 10:19 PM
cuda69's Avatar
Engine: 305TPI
Originally posted by Air_Adam
What he said.
thats what i thought but needed to be sure,thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
