headers y pipe and catback
Old Oct 3, 2005 | 10:29 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I just recieved my order of header's,y- pipe,and catback from summit! The problem is that I can not put anything on! I know i can do the cat back at least but there is not enough room between the heat sheild and the differential. I also cant put the header's and y-pipe on. Please help Im 14 on limmited budget and trying to afford a new paint job!
Old Oct 10, 2005 | 07:19 AM
sp63
Guest
Posts: n/a
if i lvied in newjersey id stop by and help you. sorry. im in chicago.
i suggest you take it to a dealership and tell THEM to install the stuff. it will rpolly cost 2-3 hours (figure about 300 bucks) and thats that.
Old Oct 10, 2005 | 03:14 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
3 hours for the catback? or everything?
Old Oct 10, 2005 | 03:20 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Its probably not as bad as you think it is. I just did this myself. It takes some time and patience, but you can do it. Make sure you support the car with jackstands before working under it. Read the directions also. It will probably take you a good weekend, but the money you will save is worth it. Get some of your friends together and get some pizza. When its done you'll be glad you did it yourself.
Old Oct 10, 2005 | 03:42 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
What headers did you get? That will determine how hard they are to put on. Most headers are probably going to require plug wires with 90* boots on them. If you are going from stock everything to headers, then it will take longer than 3 hours. My first set took about 12 hours including removing all smog equipment, removing exhaust, unbolting motor mount and jacking engine up, and my favorite.... installing stage 8 locking header bolts. I wonder how I used the stock plug wires on that one.... Pull ties, maybe?
Old Oct 10, 2005 | 07:36 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I did try we cant get it over the differential I was thinking about cutting the pipe were it goes over there and then getting a welder or some one to weld the pipe back together
Old Oct 10, 2005 | 08:22 PM
Car: 92 Z28
If its one long exhaust pipe from cat to muffler, its had to get it over the rear end. Seems like I had to remove the p/s rear tire, shock and spring. Them just slid it on. Try and get the car as high off the ground as you can. Is this a stock cat back? What brand parts are you using?
Old Oct 11, 2005 | 07:22 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Dynomax i should have gotten hooker I am never going cheap with my car ever again!!
Old Oct 11, 2005 | 07:46 PM
LT1FUN's Avatar
I got my 3" dynomax cat-back not too long ago and I LOVE it!!
Nice mellow tone to it and no resonance inside the car like you would with hooker/flowmaster. Just a nice smooth, DEEP, tone. It has gotton a bit louder in the past few weeks but still not enough to be annoying.
At WOT it's got a very refined sound with no raspiness what so ever. Like I said, I love it.
Dynomax also flow equal to or better than any aftermarket exhaust for our car's.
I have an issue of GMHTP where they picked up a solid 2/10s of a second in the 1/4 mile on a TPI firebird.
It's an excellent exhaust system that would be a lot more popular if it only had a more "agressive" sound to it. (Everybody seems to want "LOUD & ANNOYING" nowadays )
Old Oct 12, 2005 | 03:34 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Mine is 2.5 Does it back fire alot? I WANT IT TO BACK FIRE!!
Old Oct 12, 2005 | 04:16 PM
Car: 92 Z28
My 3inch blowmaster backfires. It will get louder as time goes by.
Old Oct 12, 2005 | 04:29 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
My freind has a 86 tpi with edelbrock headers and flow masters it sounds pretty cool only back fires when its cold
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
