hedman lt pics
Old Oct 16, 2005 | 12:11 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
hedman lt pics
I've been gathering ideas for my dual exhaust set up. I've seen a lot of good pics, but not exactly what I'm looking for. Does anyone have a clear pic of the hedman long tube collectors? From what I can tell they run along the tranny, inside the frames and stop just before the VSS. Is this correct?
Old Oct 16, 2005 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They stop up at the bellhousing.
Old Oct 16, 2005 | 02:04 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
does anyone make a ypipe for those headers?
Old Oct 16, 2005 | 02:10 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Ok, so can I run pipe straight back, or will the crossmember interfere? Will the hedman s-extensions clear the crossmember if I go under it?
Old Oct 16, 2005 | 03:45 PM
klumb15's Avatar
check out my cardomain page......true duals with headman LT's...
http://www.cardomain.com/ride/775842/6
Old Oct 16, 2005 | 11:05 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Ok now I'm starting to get a better idea of what to do. Looks like the major obstacle is the crossmember. It looks like the s- extensions will work. After seeing the pics though I might just hack up my crossmember and run straight pipe. Any suggestions? I'd like to do this as cheaply as possible so I'm trying to keep it outta the muffler shop.
Old Oct 16, 2005 | 11:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you have an automatic you might not have a lot of room to run pipe after you hack the crossmember. The shift cable especially won't like being too close to the exhaust.
Old Oct 16, 2005 | 11:43 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
So the best route would be under the crossmember?
Old Oct 16, 2005 | 11:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Under the crossmember, or around the frame rails in the front. However you can manage it.
It's not that hacking the crossmember won't work, but you'll have to look at how much more clearance you'll actually get to see if it's worth it.
Old Oct 18, 2005 | 09:45 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Check it out........ The crossmember for the tranny will get in the way! I know mine is a single system, but you'll run into the same problem. The pipes gotta go under the crossmember. I'm gonna fab my own crossmember
plm99
Southern California Area
Nov 16, 2015 05:21 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
WickedBowtie
Sep 11, 2015 11:24 PM
