Pass side header what is that vavle between it tand the y pipe?
Old Nov 4, 2005 | 08:16 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have wondering if it is some kind of heat vavle and how could I remove it? thanks
Old Nov 4, 2005 | 10:02 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
im not sure what it is called right off but it is a valve that stays closed or somewhat closed before the motor is warmed up to actually help it warm faster by keeping heat in the motor until it reaches operating temp. atleast that is what my exhaust guy told me because mine was roken and was rattleing and i thought it was my brand new catco cat so it turned out to be that instead. im unsure how to remove it but you coud always take the buterfly out of it. thats what im thinking of doing.
Old Nov 4, 2005 | 11:01 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
One word, Headers
Done
Old Nov 4, 2005 | 11:33 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
It's called the EFE valve.
Just unbolt the y-pipe, take off the valve and put the y-pipe back on.
Old Nov 5, 2005 | 12:11 AM
Screamin86's Avatar
i agree just remove it or what
84z28350 said headers
Old Nov 5, 2005 | 04:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, TPI cars have a spacer there which looks like the EFE valve but which has no butterfly.
JamesC
Old Nov 5, 2005 | 06:48 PM
BLACK Z's Avatar
Car: 86 Z28
I have the edelbrock headers on the car and it still has it, I was wondering if I could just remove it and if they made a spacer for it. thanks
P.S would the TPI one fit?
Old Nov 5, 2005 | 07:31 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Man, none of my cars have had that thing
Old Nov 6, 2005 | 06:35 PM
Nate86's Avatar
Engine: 4 cylinder
Fuel injected engines have no need for it. IIRC, the EFE valve's purpose was to keep fuel from pooling up in cold conditions on carbureted cars.
Old Nov 7, 2005 | 05:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Port injection cars have no need for it. It is intended to keep fuel from pooling in the plenum. Dry plenum, no need. Wet plenum, "need".
(I haven't been running it on the Camaro since 2001. Haven't run it on the '57 since...)
Old Nov 19, 2005 | 07:12 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
is it the same like a 02 sensor? can you run 02 sensor instead of a efe valve in a LG4?
Old Nov 19, 2005 | 08:23 PM
JamesC's Avatar
No. Entirely different.
JamesC
Old Nov 20, 2005 | 05:52 PM
Nate86's Avatar
Engine: 4 cylinder
There is already an O2 sensor on your LG4, and you definately don't want to remove it. The EFE valve only works during cold operating conditions, anyway.
I removed mine and haven't noticed a bit of difference since.
Old Nov 20, 2005 | 05:59 PM
JamesC's Avatar
Probably in Florida you wouldn't .
JamesC
Old Nov 20, 2005 | 08:35 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
are the air tube and efe valve the same?
Old Nov 21, 2005 | 11:26 AM
Nate86's Avatar
Engine: 4 cylinder
No, the A.I.R. injection system is completely seperate from the EFE valve. The EFE valve is it's own seperate system, devoid of interaction with any other emissions system.
Sorry to be rude, but your questions are becoming redundant. Just go under your car and look up at the y-pipe near the passenger side. You'll see it.
Old Nov 21, 2005 | 09:41 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
thanks for the help.
Old Nov 24, 2005 | 12:17 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
if you dont want to get a set of headers (which you should), just cut the butterfly out and stick a bolt through the hole in it's place. worked great for me until he headers showed up.
Old Nov 24, 2005 | 09:49 AM
BLACK Z's Avatar
Car: 86 Z28
I have the edelbrock headers on the car.
Old Nov 24, 2005 | 10:08 AM
JamesC's Avatar
The TPI version would fit.
JamesC
Old Nov 24, 2005 | 07:38 PM
BLACK Z's Avatar
Car: 86 Z28
When you say the tpi version will fit what do you mean? the headers or the spacer? I f I ever did get the headers, would it still bolt up to the cat back? I think the tpi cars have a bigger y pipe.
Old Nov 25, 2005 | 09:15 AM
JamesC's Avatar
The L69/LG4 EFE valve, IIRC, are identical. The only difference between those two and the TPI version is that there is no butterfly. Either way, the valve would be restrictive. As others have suggested, remove it. The valve would have nothing to do with the catback.
JamesC
Old Nov 29, 2005 | 03:36 PM
BLACK Z's Avatar
Car: 86 Z28
I was taling about if I brought the complete header system for a tpi car.
Old Nov 29, 2005 | 04:46 PM
five7kid's Avatar
The L69 EFE valve is larger than the LG4 valve.
The TES headers for LG4 make provision for the EFE valve, meaning the y-pipe is bent/sized for it. The TPI TES do not make provision for an EFE valve, since TPI didn't have it from the factory, so the y-pipe is bent/sized for not having it.
Old Nov 30, 2005 | 10:48 AM
BLACK Z's Avatar
Car: 86 Z28
Ok, when I brought my cat back it was for a lg4 and meant to fit the headers, I think the tpi cars had bigger headers/y pipe, will the flange still bolt up where the y pipe and the cat back meet up?
Old Nov 30, 2005 | 11:00 AM
JamesC's Avatar
A muffler shop can do what needs to be done.
JamesC
Old May 10, 2006 | 11:38 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
anyone have problems with that thing rattleing like a rattle snake during warm-up under heavy accle? then stop after it reaches specs? or at a light and floor it and rattles for a second or so...?
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
3rdgenparts
Aug 5, 2015 11:57 PM
