exhaust idea
Old Nov 27, 2005 | 03:37 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
exhaust idea
i am planning on putting a mildly built 383 stroker in my car and was just thinking of ideas for the exhaust. What do you think of this
-hedman long tubes
-dual 3" to a flowmaster 50 series
-dual out, over the axle and dump right before the rear bumper
-all tucked up very nice
-sorry for the crappy paint illustration
Old Nov 27, 2005 | 04:00 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
It's been done before.
Old Nov 27, 2005 | 04:07 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
That's gonna hurt ground clearance right there I bet. Run it over the axle then hit the mufflers.
Old Nov 27, 2005 | 04:13 PM
MaNiAk86's Avatar
Car: 1983 trans am
i dont think theres enough room to run 2 mufflers after the axle
Old Nov 27, 2005 | 04:15 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
ya u might have some porblems with clearence
Old Nov 27, 2005 | 04:20 PM
Car: 86 T/A
Engine: HSR 355
I know for a fact that there is.
Old Nov 27, 2005 | 06:36 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what part number on the long tube hedmans ?
thanks
Old Nov 27, 2005 | 07:35 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
68460
um...how are you planning on getting the ds pipe to the ps? it's going to decrease your clearance there just as much as it would if you ran duals in the traditional spot, then when up and over the axle...and you can run a pipe over the axle on the ds...look at deadbird's setup.
Old Nov 27, 2005 | 07:43 PM
MaNiAk86's Avatar
Car: 1983 trans am
fast68- the part # in my summit catalog is HED-68466
mw66nova- do u have a link to a pic of deadbird's set up.
i am open to options
Old Nov 27, 2005 | 07:45 PM
MaNiAk86's Avatar
Car: 1983 trans am
how are the Summit brand headers?
has anyone had any experience with them. theyre very cheap
Old Nov 27, 2005 | 07:46 PM
mw66nova's Avatar
Engine: 7.0L
search for deadbird on here in the exhaust forum....there are tons of threads with his pictures in them.
summit's headers are essentially flowtechs...they SUCK for performance parts...if your just going with something a little better than stock...OK. but if you want the best bang for your buck...hedman longtubes my friend.
Old Nov 27, 2005 | 08:38 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
6846o
do these fit with stock large style starter and stock engine mounts ?
ive been seeing ppl having problems with starters not clearing with the 2210 headers
it looks like 6846o are the way to go
thanks
Old Nov 27, 2005 | 10:40 PM
mw66nova's Avatar
Engine: 7.0L
the o is actualy a zerio 6846zero(0)
nope, no starter or motor mount clearance issues. the starter will have to be removed, the reinstalled for header installation...no biggie. also, you *may* have to do a small amount of trimming on the a-arm mount on the crossmember. not that big of a deal, nothing a handheld grinding wheel can't handle.
Old Nov 27, 2005 | 11:05 PM
MaNiAk86's Avatar
Car: 1983 trans am
thanks for all the input guys. I no what headers im gonna get, but im still not sure how to run the exhaust
Old Nov 27, 2005 | 11:06 PM
mw66nova's Avatar
Engine: 7.0L
like this:
https://www.thirdgen.org/techbb2/sho...hreadid=333490
Old Nov 28, 2005 | 05:59 PM
MaNiAk86's Avatar
Car: 1983 trans am
i like ur setup but i dont want the exhaust to dump before the axle. do u think theres room to run them over the axle then dump before the bumper?
Old Nov 28, 2005 | 08:33 PM
mw66nova's Avatar
Engine: 7.0L
you would have to move the mufflers towards the front about 6-8" then you would have plenty of room to go up and over the axle.
Old Nov 28, 2005 | 10:49 PM
MaNiAk86's Avatar
Car: 1983 trans am
what mufflers are you using? what are the dimensions?
How do u like the sound?
Old Nov 29, 2005 | 06:06 AM
mw66nova's Avatar
Engine: 7.0L
i love the sound, can't beat the sound of dual exhuast with an h-pipe. for dimensions, look up summit p/n 633222, it's a summit brand muffler.
Old Nov 30, 2005 | 05:40 PM
MaNiAk86's Avatar
Car: 1983 trans am
i like the setup but i heard the sound clip and its a bit too muffled for me . ill probably go with dual flowmaster 40 series. those new edelbrock mufflers look good, has anyone tried them?
Old Nov 30, 2005 | 07:10 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Do oyu have to use headman longubes for mw66nova's setup or can you use anything else?
Old Dec 1, 2005 | 01:04 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
muffler fits good in the slot made for the cat
Old Dec 1, 2005 | 10:54 AM
MaNiAk86's Avatar
Car: 1983 trans am
u dont want the muffler that close to the engine. it causes power loss. the farther away the muffler the better.
Old Dec 1, 2005 | 11:30 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
There is a better way to do it than this. First check out ******* dual 2.5inch setup.
Willie's exhaust
Now here is the real good one. This is Greezemonkey's setup.
Greezemonkey's exhaust
(Just scroll about 3/4 of the way down.)
Old Dec 1, 2005 | 09:41 PM
mw66nova's Avatar
Engine: 7.0L
how d'ya figure? all the pro-mod and pro-outlaw guys run their mufflers right on the collector of the headers...
Old Dec 1, 2005 | 09:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They generally don't have 10 feet of pipe after the muffler.
Old Dec 1, 2005 | 09:50 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Hey...MaNiAk86 what color is your car? I love the color.
Old Dec 1, 2005 | 11:44 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
on the *****'s exaust....gmmg is expensive... but it sounds nice...
Old Dec 2, 2005 | 10:30 AM
mw66nova's Avatar
Engine: 7.0L
willie does not use the gmmg. his is completely custom.
Old Dec 2, 2005 | 04:45 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
ive got a quick question. i havent been around long enough, unfortunately, to know the answer. would a 2 1/2" dual setup with mufflers (2 obviously) be noticably louder than a 3" single with just 1 muffler??? or vise versa? (assuming both are dumped before rearend) or even a dual with a 2-in, 2-out muffler.?
reason i ask, im thinking of doing something like this. theres just no room!!!
(btw i have done searches for this and i dont mean to take over anyones thread thanks)
Old Dec 2, 2005 | 05:05 PM
mw66nova's Avatar
Engine: 7.0L
it will be louder, but also, it'll have a much cooler tone, esecially if you use some sort of crossover pipe (either an H or X pipe.)
Old Dec 3, 2005 | 05:16 PM
MaNiAk86's Avatar
Car: 1983 trans am
i think i wanna go with ur setup mw66nova. hedman longtues to H-pipe to 3"in/out 40 series flowmasters with the flowmaster scavenger turndowns.
is urs 3"?
Old Dec 3, 2005 | 08:13 PM
mw66nova's Avatar
Engine: 7.0L
no, mine is 2 1/2". it supports my dads 550hp z28...and it gives me the best ground clearance.
Old Dec 3, 2005 | 08:46 PM
MaNiAk86's Avatar
Car: 1983 trans am
well my motor should only be around 450hp so i think 2 1/2 will be adequate. thanx for all the help
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 7, 2015 09:55 PM
