Between the converter and the Y-pipe
Old Jan 7, 2006 | 08:39 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Ok from the fcatory, where the y-pipe goes into the converter, is it just connected with a clamp or is it welded? My clamp is like gone and it just looks like its rusted on.
Old Jan 7, 2006 | 09:18 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
You mean whether the cat converter is welded on or clamped on ?
Old Jan 7, 2006 | 10:57 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
On my dual-cat car, one of my cats is stock (ask and I'll tell you how bad it gets): the 2 1/4" pipe goes straight into the front of the cat and is connected to the f-pipe by a bolt connection. The non-stock cat is welded in the front to the downpipe and is u-clamped at the rear to the f-pipe.
If you are replacing your stock cats (hopefully you are) then you can cut the pipe from the cat. I will be replacing both of my cats and may be using band-clamps front and rear.
BTW, anyone know where I can get 2.5" N10 downpipes? I've checked Summit, Edelbrock, Jeg's, Dynomax, Muflfex.....I'm thinking I'm gonna have to fab them from the Dynomax assortment of mandel pieces.
Old Jan 7, 2006 | 02:21 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I think catco makes a N10 replacement dual cat setup that contains two high flow cats, and 2.5" piping conecting the cats to the manifolds.
Old Jan 7, 2006 | 02:23 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Here's the link:
It's expensive
The part # is CTO-4153 I can't get the link above to work.
Old Jan 7, 2006 | 03:00 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Holy crap, that's SOO close to what I need! I don't think I can thank you enough SGM. Hope I can be of some help to you someday.
THANK YOU..Eric
Old Jan 7, 2006 | 03:49 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
You make me feel special
No prob,
Campi
Old Jan 7, 2006 | 04:41 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Geez, get a room!!
Old Jan 7, 2006 | 05:19 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Old Jan 7, 2006 | 06:54 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Ok ok, since it appears I have created a love-fest, I'll put a stop to it. I'm still gonna piece together a full 2 1/2 " setup. I was gonna try and do true dual, but a few factors killed that idea. So I'm gonna stick to my plan-b here w/ 2-2 1/2" from the headers out to the cats then out to a 3 1/2" Mufflex w/ spintech, out to 3" tailpipes.
Good times in the garage to come.......
Old Jan 8, 2006 | 08:14 AM
Rob Wade's Avatar
I'm jealous. Nothing better than lying on your back welding and a hot molten piece of metal rolls under your back!! Ahhhhh....good times!! Good luck with the project.
Old Jan 8, 2006 | 08:27 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
Oh no..I am not going to weld, got no idea how to do that. Notice I said "piece together". I'm gonna let a pro weld it up for me after I'm done.
I did some more digging and found out that those 3 1/2" Mufflex's are only after the f-pipe behind the cats. I'm confused as to how effective that really is. I'm under the impression that the f-pipe isn't 3 1/2" around..maybe 3"? I dunno, I wouldn't think that going 2 1/2" thru cats, then out to 3" (or whatever), then out to 3 1/2" is kind of counterproductive. Please enlighten me.
Old Jan 8, 2006 | 11:36 AM
Rob Wade's Avatar
When you say f-pipe what do you mean. Stock y pipe can be 2 1/2 or 3" into cat and either 2 1/2 or 3" for the intermediate pipe to the muffler.
Old Jan 8, 2006 | 11:47 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
I neglected to mention I have an N10 car. I am talking about the pipe AFTER the 2 cats that merge into 1 and then go into I-pipe. My thinking was that it seems to be the prevailing logic that the best flow would be achieved from a single pipe diameter all the way through as opposed to 3 different diameters, steadily incresing from the headers out to the muffs.
Old Jan 8, 2006 | 01:34 PM
Rob Wade's Avatar
Not necassarily. If you look at a "stepped header" this type of exhaust works very well. What you really want to look at is the cost of going with the larger pieces and how much of a performance gain you will get by increasing the diameter as you work backwards. At the end of the day you will see minimal gains by going larger than 3" past the converter. You will see gains, just not earth shattering gains. So how much is it worth to you? Only you can decide that.
Old Jan 8, 2006 | 02:49 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
You're right about the cost vs. gain. I calculated all I was gonna have to do for the 3.5" cat-back set up and how much my true-dual would be if i DIY it. I was kind of surprised that the DIY true-dual will end up costing me less. So, back to plan-a.
I had never heard or read anything about the progressive pipe diameter. Glad I asked.
I also found a puncture in one of my cats yesterday. Another reason I can't wait to tear the exhuast out of this car. Pipes flattened. Bends flattened. Crinkle-bent pipes. 1 stock cat, an aftermarket cat 1/2 the size of the stocker. Welds that look like they were done in shop class. AIR system going to ONE HEADER....and that's all. I am happy w/ my exhaust sound, but form must indeed follow function. Yeah, we're goin true-dual!
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
okfoz
Oct 13, 2015 02:19 PM
loud91rs
Oct 5, 2015 10:05 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
