Header Question, Dual cats
Old Jan 10, 2006 | 10:47 PM
RY-Rai8ers's Avatar
Car: 89 Iroc
Engine: The 350
After a few days of reading posts and searching the existing threads, I still dont have the information I need about headers for the dual cat setup. I am aware that SLP and Headman makes them, but i couldnt find the exact part on any of the online sites. Does anyone here know good headers for the dual cats? part names and numbers would be great.
Also, what would have to be done to use something like the hooker 2055's which are a single cat setup? and would having a dual cat setup be more restrictive or better flowing than single?
Thanks for the help, sorry if this is a common question, I just couldnt find what I was looking for.
EDIT: By the way, I have stock cats with an American Thunder system following. If this matters
Old Jan 10, 2006 | 11:22 PM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
You can't delete a cat and be smog legal in California. Get the headers of your choice (I got the SLPS) and have someone fab up a custom dual cat y-pipe for ya.
Old Jan 11, 2006 | 12:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's not a very good answer, because whatever headers you get need to be CARB certified, and if they're CARB certified, they'll have the y-pipe. If they have the y-pipe, they have to be made for dual cats.
Hedman & Edelbrock are the only ones still making dual cat headers. SLP doesn't offer them anymore. Personally, if I had dual cats, I'd go with the Hedmans. P/N 68491 (check the Hedman site, www.hedman.com , for the application - footnote 145. The Summit site has the application wrong).
Old Jan 11, 2006 | 01:27 AM
Car: 91 Formula WS6
Of course the headers need a CARB EO. That's so engrained in me as a lifelong California resident I forgot to state it. I go as far as to take the EOs with me to the smog inspection. With the current tact of law enforcement here it would not be a bad idea to keep your EO paperwork in the glovebox.
The SLP headers do have a CARB EO and I had to come up with another solution for the y-pipe that incorporates dual cats. Most folks will want a more straightforward solution like those offering the stock in box dual cat y-pipe. I had the Edelbrock TES on my '89 Formula 350, it was a PITA to install but worked well. Don't know about the Hedmans, I don't have any experience with them.
Old Jan 14, 2006 | 02:58 AM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Re: Header Question, Dual cats
Hey I got a set of 2056's,shorty headers from hooker made for dual cat setup. Complete 3" pipes and the headers are 1 5/8 primaries with everything you need, gaskets and hardware included.I ordered the wrongs one (need the 2055's w/ y pipe), if you wanna buy them Ill let them go. They are discontinued now from what I hear. Theyre brand new and never used. Let me know.I need to sell these.
Old Jan 14, 2006 | 07:59 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
How in the world do you all put up with that crap in CA? I would go hang my self.
Old Jan 14, 2006 | 12:02 PM
90Zdrifter's Avatar
Car: 1990 iroc-z
Engine: 5.7 tpi
Transmission: 700-r4
Axle/Gears: 9 bolt borg warner/3.27
I own a 1990 iroc 5.7 tpi with dual cats. I am having the same problem finding headers for this setup. After months of seaching the only two still on the market are edelbrock and hedman. I don't know how much mods are needed to fit to the dual cats. Both manufacturers require cuting and welding.
Old Jan 14, 2006 | 01:55 PM
Car: 91 Formula WS6
Unless you are planning to do the install of the headers and y-pipe yourself it is a job that a good exhaust guy could do.
Old Jan 16, 2006 | 12:23 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
90Z, I have the Edelbrock headers and dual cats. I actually had an old Edelbrock set on the car when I bought it. What the item consists of are 2 headers and 2-2.5" down pipe extensions. Your dual cat car has 2-2.25" pipes from the stock exhaust manifold to your cats. I believe the collector on these is around 3" (outside circumference) and the Edelbrock-supplied pipes are similiar to the ball-flange type fitting to the headers. The actual inside of the pipe is 2.5". You'd need to cut off the stock pipes aft of the header and weld up the Edel-supplied replacements.
Hope this helps
Eric
Old Jan 16, 2006 | 09:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have 320 HP at the wheels and pass the sniffer every time. We have guys in our club with 360+ to the wheels and they pass too. Its very easy to make a smog legal car and still have lots of horsepower. You just have to be smarter about it.
SLP, Hedman, and Hooker are very good headers. Stay away from Edelbrock. Their design has too many compromises.
I have the SLP's modified to work with the Corvette EGR, and my father fabricated a 2.5" custom dual-cat y-pipe. Come over to the SoCal site and hook up with us and he can do the same for you.
Old Jan 16, 2006 | 10:14 PM
Car: 91 Formula WS6
Well Hello Kevin! Still don't like Edelbrock eh? At least we agree on California...I'm too busy with my legal hp and deciding whether I want to ski, surf or go to the desert.
Old Jan 17, 2006 | 07:44 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Hundreds of miles of beaches...
Mountains and scenery...
Beautiful women...
Sunny year round...
Tons of nightlife and things to do...
Makes the smog stuff sound kinda petty if you ask me
Old Jan 18, 2006 | 09:30 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Beautiful women...
Sunny year round...
Old Jan 18, 2006 | 10:56 AM
stitchop's Avatar
Car: 91 firebird
Arkansas;
No beaches...
Hillbillies and hicks...
Beautiful women (cousins!)...
Hot summers, cold wet winters...
No nightlife not much to do...
NO VEHICHLE INSPECTIONS!!!
onefreakz
May 14, 2018 12:15 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
redmaroz
Aug 16, 2015 11:40 PM
