cat glows red hot on idle!
Old Jan 28, 2006 | 12:42 PM
copperchick's Avatar
Car: 1984 Z/28
Engine: 383 stroker
Wow...long time no see. Anyway, here's what I've got...
383 stroker
RPM Airgap intake
Holley 670 cfm Street Aveneger carb
SLP 1 3/4" headers to 3" y-pipe
high-flow Catco cat
3" I-pipe
Flowmaster muffler
Everything is fresh and new. The cat glows red hot on idle. Anyone seen this before? It's pretty freaky. Any thoughts on how one might go about resolving this pesky little issue?
Old Jan 28, 2006 | 12:48 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Anytime I've ever heard of a cat glowing red was when it was bad/clogged. My buddy also had that problem, but he was running too lean. He said when he fixed the lean condition, it stopped glowing red.
Old Jan 28, 2006 | 02:08 PM
Car: 1984 Z/28
Engine: 383 stroker
It's brand new...but I wonder if it's just a dud? I spose it could happen.
Old Jan 29, 2006 | 12:36 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Could be......thats the only time I have ever heard of them getting cherry red is when they are plugged, or otherwise not flowing properly
Old Jan 29, 2006 | 08:03 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I had this happen on my wifes old 88 buick regal we once had. It was running very rich (bad coil pack) and it was glowing cherry red. I figured that the extra fuel in the exhaust was heating the cat up much hotter than normal and caused the glowing.
Old Jan 29, 2006 | 08:12 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
How does the car run, any misses?? Any power loss??
Old Jan 30, 2006 | 09:34 AM
Car: 1984 Z/28
Engine: 383 stroker
Everything's fresh andfreshly installed so there are a few sputters to be worked out.
Old Feb 3, 2006 | 01:27 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
yes you are more than likely running really rich i was working on a car that did this found the problem in the ignition system and make sure to inspect the cat now that its been overheated now
Old Feb 4, 2006 | 09:40 AM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I had this problem before with my camaro. The carb was dumping way more fuel than it could burn due to a blown power valve. The excess fuel ignites in the cat due to the extreme temp which is it's whole purpose in the first place. I got one so hot that the welded seems split. A new power valve, spark plugs and wires, coil, and cat later, I was good to go.
Old Feb 4, 2006 | 12:59 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
yes thats what i meant about running really rich
Old Feb 4, 2006 | 02:42 PM
Car: 1988 IROC-Z
Engine: 427 SBC
^ Idiot. Meant rich condition.
Old Feb 4, 2006 | 04:52 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
Its running really rich. The coverter is red hot because it is trying to burn all the excess fuel. It also could be a dead cylinder dumping fuel as well. Make sure your not missfireing if not backprobe the 02 sensor and see how rich it is running. Then take off the cat and look at it.
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 21, 2015 07:20 PM
gta power
Aug 13, 2015 06:15 AM
