Problems w/ Tailpipe Fitment!! Help!
Old Mar 25, 2006 | 09:59 AM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Ok i have the Hooker catback in my basement ready to be installed. I bought the Dynomax direct fit turndown tailpipes for the kit, seeing as i dont like any time of flashy exhaust tips. The problem i recently realized is that the muffler outlets have an OD of 2.5 inches, whereas the dynomax tailpipes also have an OD of 2.5...so they dont really fit.
I have 2 questions: More than likely i'm going to be taking my car to an exhaust shop to have it installed, so i would assume they would have no problem fitting the tailpipes on the muffler, correct? But if i do choose to install it at home, is there anyway to install the tailpipes correctly??
and btw, i already sold the hooker tailpipes and tips to my friend..so i cant put them on.
Old Mar 25, 2006 | 08:24 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
If you take it to an exhaust shop they will have no problem installing the tailpipes. They should have a machine that can expand the pipe.
Old Mar 25, 2006 | 10:40 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
If you'd prefer to install them yourself and save the cost of having a shop install them, then just take the tailpipes and have the inlet expanded to 2.5" ID(which they probably should've been already because they should've been made to fit 2.5" OD muffler outlets). The shop will probably charge you $5-$10 each to expand them, then take them home and install them.
gta power
Aug 13, 2015 06:15 AM
TRAXION
Nov 11, 2002 03:31 AM
L.I.N.Y.92CAMARO
Aug 27, 2002 12:44 AM
Adams87Camaro
Aug 6, 2002 01:43 PM
BigL350
Jun 16, 2002 10:24 PM
