Locking Header Bolts
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've beenthrough several header bolt options, and nothing stays in - they all loosen and blow my header gasket. Anyone recommend a good locking header bolt?
I see on Summit Racing - Stage 8 & Bresslin Performance. I like the way the Bresslin bolt works (or looks like it works lol), but I'd like some opinions on some different brands (these or others) before I drop those big bucks on another set of bolts. Thanks all.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I use grade 8's with a lock washer and standard washer and they have been fine. Might not be what you want, but it's worked for me.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I use the Stage 8 bolts and my next set of headers will have Breslin's. They will work with any header combination whereas the Stage 8's work with only a few sets. The locking tabs are a clever design but will interfere with most header primaries. The breslins internal locking system avoids all clearance issues.
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
stage 8s went on with little trouble, but seem to be working fine.
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
all. I worried the locking screw would seize, but no problems..
Car: 1992 RS
Engine: Carbed 350
Great - thanks for the replies.
I've also read to try the red locktite - I might try it with the lock washer mentioned above on just one, before I put in a new gasket, just to see what happens - that $60 a set for the Bresslin's is hard to swallow right now!
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
