headers for 113 heads?
Old May 2, 2006 | 07:45 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
who makes the headers for the aluminum 113 corvette heads? i'm thinking you have to mod the flanges by ovaling mounting holes. anybody know? they have a raised exhaust port and angled plugs...just to make things difficult..
Old May 2, 2006 | 11:13 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you can use any thirdgen header, though i'm running the hedman longtubes. no modifications necessary.
Old May 2, 2006 | 12:00 PM
wdigitog's Avatar
should i use the larger tubes? 13/4"?...it looks like the openings won't match up.....you sure?
Old May 2, 2006 | 06:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
1-3/4" is a BIG header for a 305, unless its got some sort of power adder on it. The openings would match up just fine, a SBC is a SBC. The only difference with the 113 heads is the D-shaped exhaust ports, but that shouldn't cause any problems as far as headers go.
I'd suggest using a 1-5/8" header on your 305 though. 1-3/4" is not really going to be worth the extra money unless you actually need the extra breathing capacity, or plan to change to a larger motor later (ie. 350, 383, 400...)
Old May 2, 2006 | 07:14 PM
wdigitog's Avatar
the heads are going on a 350....
Old May 2, 2006 | 08:23 PM
Air_Adam's Avatar
1-3/4 would be good for a 350, and they should cover the D-ports just fine.
Old May 3, 2006 | 01:28 AM
mw66nova's Avatar
Engine: 7.0L
i'm positive, this is the combo i'm using and have been 12.16@110mph babying it out the hole with MUCH more to gain. a 1 3/4" header will gain you nothing but a lighter wallet unless your running bigger cubes (383+) or a power adder of sorts.
Old May 3, 2006 | 08:00 PM
wdigitog's Avatar
hedman just gave me part # 68309 for the heads......don't know much more.
Old May 3, 2006 | 10:23 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
look at hedmans part listings, they make D port specific headers.
Old May 4, 2006 | 12:18 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The centerline is also raised .100" higher than the bolt holes. I have these heads and I know. Any standard 1 5/8" header will just barely clear, as long as you grind out any welding slag from the inside. A better choice is a 1 3/4" header. Think about it. People will say running larger valves on your heads is a good idea, for example 1.60" exhaust valves, so why would you then restrict it with a 1.625" outside diameter header? Also, hot exhaust wants to expand. Giving it a larger path to exit will be beneficial.
Old May 4, 2006 | 06:06 AM
wdigitog's Avatar
makes sense, kevin....was there space on the flange to elongate the holes? i was thinking of doing that the centerline is just 0.10 off...
lt500r55
Sep 1, 2021 01:30 PM
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Ducati900ss
Sep 2, 2015 09:05 AM
hayesaw0210
Aug 23, 2015 11:15 PM
