what muffler can i put on a v6?
Old Jun 1, 2006 | 03:49 PM
redfirebirdman8's Avatar
Car: '89 Trans Am
Engine: 305 T.P.I.
Axle/Gears: 10 bolt 3.73’s
hey guys ive been thinkin about a flowmaster super 80 but i dont know if you can put that on the v6 (88 bird 5speed) its single inlet dual outlet, or can ive been thinkin of a glasspack but i think it will be too loud and ill get pulled over all the time. what do you guys have on ur car?
Old Jun 1, 2006 | 04:21 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
There is a direct-fit muffler that flowmaster makes. Don't get a glasspack, I'd imagine it to sound bad.
Old Jun 1, 2006 | 06:16 PM
Car: '89 Trans Am
Engine: 305 T.P.I.
u know what its called?
Old Jun 1, 2006 | 08:22 PM
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
Its the 80 series, but it your putting it on a stock I pipe youll need to get an adapter to fit a 2.5inch inlet.
Completely forget any idea of a glasspack on your v6
Old Jun 1, 2006 | 09:44 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
look on summit or Jegs. It's direct fit. I know adapters are cheap too. Why not just get a cat-back?
Old Jun 2, 2006 | 04:39 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Get a 350 first.
Old Jun 2, 2006 | 05:26 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Do NOT put a flowmaster 80 on a v6 5 speed car. I made that mistake and it was the worst thing I ever did to that thing. Before that I had a Dynomax super turbo muffler and that thing was great. The 80 was obnoxious and rattly. A true fart pipe for a domestic.
Old Jun 5, 2006 | 01:46 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I disagree... maybe on the iron head 2.8 it sounded bad but it was pretty decent on my aluminium head 3.1.. also pretty good on a worked over 3400 SFI.
Loud as can be but still has a good tone.
3.1/80 series: http://www.superdave81.com/AV/80series.wmv
Old Jun 5, 2006 | 02:32 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Depends on which glasspack you get.
Old Jun 5, 2006 | 03:24 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I AGREE.
The flow 80 on my old V6 was HORRIBLE.
The resonance was between 50-60 MPH where you always cruise at.
glasspacks in general sound horrid. I do not care what brand or what they are on...
Old Jun 5, 2006 | 05:23 PM
Engine: 450HP 355
Transmission: TH350
hopefully in 2 weeks i'll be able to show you guys what a crossflow Hooker Aerochamber sounds like on a V6... $80 from Summit
Old Jun 8, 2006 | 02:10 PM
Slow2.8's Avatar
I have the flow tech glasspack and i enjoy the sound although the performance isn't as good as my summit turbo which is a really good buy, 15 bux great performance and a decent sound. I switch the two mufflers out, the glass pack is for sound and looks (red) and the muffler for performance.
Old Jun 8, 2006 | 02:30 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
i have a dynomax ultra flow 2.5" mandrel bent cat back on my 2.8 sounds like an 8 at idle and its sounds pretty good higher up in the powerband, if your going for looks the muffler for this kit is "polished up like chrome" i paid around 300 for the kit, but i see you can step down to a super turbo dynomax catback for like 165 too...go with the ultra flow, and get a little more bang for your buck with the larger mandrel bent intermediate, and the mandrel bent tails...
unknown_host's Avatar
Car: 1989 Iroc Z L98
At anything over idle the flowmaster sounds horrible on the 2.8/3.1/3.4/3.8, I know because I have had friends with all the above combos. Actually, the 3.4 sounded the worst imo, it was ridiculous.
Old Jun 8, 2006 | 02:31 PM
Car: 92 Camaro RS
Engine: 5.0L
and to finish it off i got hooker chrome tips, dual 3" slashed exits on each side...maybe ill go get a digi camera soon and get out some pics....
Old Jun 8, 2006 | 08:32 PM
Car: '89 Trans Am
Engine: 305 T.P.I.
how did u set the glasspack up, i have single inlet dual outlet muffler, and a glasspack only has on inlet and one outlet?
Old Jun 9, 2006 | 12:13 AM
Engine: 450HP 355
Transmission: TH350
3.4 or 3400?
again, i can see the iron head RWD V6's sounding a little odd because of the lack of exhaust flow and just the overall nature of the V6... but when you hear one on a 250+ HP Gen3 '660 it sounds a bit meaner. Don't get me wrong, i know it's loud, drones @ 2500 RPM and really pisses off my neighbors (which is why i'm changing it) but with a little power behind it it's not too bad.. sounds pretty mean above 6200 RPM too
Now, if the original poster were to keep the stock cat converter and maybe add a resonator before the muffler it would mellow out the tone alot. Some of the cavalier guys have been known to stick a glasspack right after the cat to help out with noise as well...
Bottom line, it's hard to make a v6 sound good without an engineering degree and a Crane H272-2 cam
Old Jun 13, 2006 | 04:03 PM
Slow2.8's Avatar
Custom catback set up so I can basically put any muffler i want on the pipe exiting on the left side.
Old Jun 13, 2006 | 04:13 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
you can buy glasspacks with dual outlets i know the car max by my house sells them otherwise youd have to get a custom y pipe made. but dont waste money on glasspacks. i put one on my 91 rs and it was timid as helll barely any sound outta it and i paid over 250 bucks to have it installed. but thanks to the lifts at school it didnt last long. eventually i ripped it off in favor of no muffler but just a cat and that was it, no pipe to the back or anything. i had no problems running it like that for a little over a year until its demise on 8-15-05.
Old Jun 13, 2006 | 11:43 PM
Engine: 450HP 355
Transmission: TH350
Here is a quick clip of a built 3400 with a catco ho-flow cat and a Hooker aerochamber (Crossflow style)..
http://www.superdave81.com/AV/Hooker1.wmv
At idle it's very quiet, under load it sounds mean...
It will change a bit after I finish my headers and redo the whole exhaust in 2.5" mandrel bends, might end up quieter at idle and louder under load..
dyeager535
Aug 28, 2015 08:10 AM
Navy8125
Aug 25, 2015 08:25 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
gta power
Aug 13, 2015 06:15 AM
