Will car pass emisions with longtubes?
Old Jun 6, 2006 | 09:09 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I have the factory manifolds and just bought some longtube hedman headers.
if i install them and yank out the factory manifolds will my car pass an e test?
Speed
Old Jun 6, 2006 | 09:13 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
visual no way.
anything can pass the sniffer with tuning work.
Old Jun 7, 2006 | 09:18 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Ok, maybe you should rethink your statement just a little. In stock form, if you have a visual inspection, no, you will not pass. Now this is not to say that you cannot make them pass a visual inspection. If your car has an air system on it currently, then all you need to do is have at least 1 line going into each bank of the headers. In other words 1 line on each side. Granted the factory had it set up with a line going to each pipe but as they found out this was over kill and not needed. Check out the LT1 headers for proof. So in the end, with a little creativity and probably $100 for tubing and labor, you'll be able to pass a visual inspection.
Hopefully that's what you were lookin for.
1984HO
Mar 19, 2021 11:59 AM
onefreakz
May 14, 2018 12:15 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
wruiz
Aug 11, 2015 02:59 PM
djmarch
Aug 9, 2015 05:27 PM
