Are these rare Doug Thorley long tubes? Please identify these headers.
Old Jun 28, 2006 | 11:06 PM
centralcoaster's Avatar
Car: 1985 Corvette
Engine: TPI
Transmission: 6 speed
Axle/Gears: D44/3.45
I'm considering buying these headers for my 85 Corvette, but now I'm not sure on fitment. The seller says they are made by Thorley.
I've never seen anything like them. The Ypipe has a 4-bolt flange and looks like it'd bolt right up to my 85 Corvette cat. The part that threw me off was the upward pointing air fitting. Corvette air fittings point forward. Also, the unusual #2 primary looks like it might stick out too far and interfere with my a/c lines and cat air tube.
Have you guys seen these? Is it possible he's mistaken and these are a Camaro header? I searched but all I found was a post referring to Thorley once making a Fbody long tube, no pics.
Sorry I don't have pics of the drivers side header. He's asking $550 for the whole setup, which I think is worthwhile, IF it fits.
Old Jun 29, 2006 | 02:19 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I don't know, but the dent in the passenger-side rear primary looks horrible.
Personally, I'd get something that's tried and true, and without dents lol.
Old Jun 29, 2006 | 08:24 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
there are no good headers with dents in the primaries.
Old Jun 29, 2006 | 08:49 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Looks like a dent that is there for fitment? None the less, they still look sweet.. But so do coated Hooker long tubes.
Old Jun 29, 2006 | 10:45 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
might have better luck asking on the corvetteforums....
Old Jun 29, 2006 | 11:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The dent (deliberate for clearance) is insignificant.
Old Jun 29, 2006 | 10:31 PM
Car: 1985 Corvette
Engine: TPI
I'm asking here because I suspect they might be Camaro headers. Do they look like they'd fit a Camaro? Do they have enough clearance for that #2 primary? Is the Y-pipe configured like that on a Camaro? Does it have a 4-bolt flange cat?
Old Jun 29, 2006 | 10:52 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
no, there is no way that setup would fit an f-body without serious fitmant issues.
Old Jul 2, 2006 | 01:52 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Those are for a corvette....you can tell by the direct down motion of the primaries and the shape of the y pipe. Somewhere on those headers there will be a part #. Look for it and go to summit or jegs and see if the # comes up. Kind of look like TPIS headers.
Old Jul 4, 2006 | 12:42 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
not a sarcastic question but are you serious?
Old Jul 5, 2006 | 12:30 PM
five7kid's Avatar
Yes.
Old Jul 5, 2006 | 12:35 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
I would assume it would hamper flow. though I admit I have seen something like that before but always assumed it was bad routing due to engineer not thinking as well. but then I donno
Old Jul 10, 2006 | 09:45 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Five7Kid is right, the "dents" for clearance would have zero effect on power. I have seen thrashed, dented, patched, beat up headers used on the dyno make identical power to a fresh set out of the box. Thats why we use dynos, because what you THINK will work better, often times does not.
Old Jul 11, 2006 | 12:46 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Why would you get headers with larger size primaries in the first place then?
FYI Five7Kid was being sarcastic as evident in his second post of this thread.
Old Jul 11, 2006 | 08:51 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
What are you talking about? as soon as I saw that "dent", which is a crimp on the tube, I knew it was for clearance.
Old Jul 11, 2006 | 09:10 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That "DENT" is there so that you can install that Factory GM starter, you know the one that weighs like 30 lbs. It will NOT affect power to any large extent.
I don't know of anything else GM that uses that style of Y-Pipe. I am thinking they are for a C3 Vette.
Old Jul 11, 2006 | 10:07 AM
Engine: 400
This is a valid point. If you imagine these on your car, you would be cutting out your K member to get them to fit. They would need to have more of a "sweeping back" design to have a chance of fitting. I think I called the fitment dent first too
Old Jul 12, 2006 | 01:09 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
I wasn't questioning your knowledge of what the dent was there for. I replied to a post that said a dent in a primary will have zero effect on power.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
angel2794
Sep 8, 2015 06:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
