what catback fits?
Old Jul 27, 2006 | 07:38 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
what catback fits?
I plan on getting some hooker 2055's and a 3" inlet and outlet cat what hooker super comp catback will bolt up to this setup the one for tpi or tbi?
Old Aug 2, 2006 | 04:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
None.
You need a direct-fit cat for the '86-'90 TPI single-cat application, such as a Catco 9118. Then any cat-back for the same application will fit it.
Old Aug 2, 2006 | 05:14 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
yeah thats the cat i plan on using but im confused about the catbacks one says for 2.5" carb and tbi the other catback says for tpi with 2.75 cat but the cat # you gave me says 3" outlet so which one will bolt up? From what i seen theres only 3 choices for steel dual outlet catbacks and thats flowmaster (junk) edelbrock (heard bad things) or hooker (what i want).
Old Aug 2, 2006 | 10:38 PM
five7kid's Avatar
2.75" was the factory size pipe. That's the application you need.
Old Aug 3, 2006 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hooker headers from Jeg's (520-2055). Catco high-flow converter from Summit (CTO-9118). Hooker catback from Summit (HOK-16823HKR). Great flow, great sound. Recommended.
JamesC
Old Aug 3, 2006 | 11:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Going with an aftermarket slip-on cat makes life a lot easier when you decide to modify the exhaust. I have a 3" slip-on dynomax on my car, and any 3" catback will fit simply by cutting off the stock cat-flange from the end of the pipe, and using a 3" pipe expander to expand the pipe so the cat can slip right in. Same thing if you have a 3" y-pipe. In my case I've got a 2.5" y-pipe, so I had to use a 2.5-3" adapter piece.
Old Aug 3, 2006 | 04:15 PM
five7kid's Avatar
I thought I was "smart" getting a 3" universal cat. One of the worst decisions I ever made. Ended up costing me more by the time it was adapted to the cat-back than it would have been to get a direct-fit cat.
If you're going to modify the exhaust to improve over what you can do with a single 3" exhaust, you probably aren't going to have a cat, anyway. Or a 3" y-pipe.
Logan Bryant
Sep 18, 2016 09:27 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
