new exhuast
Old Aug 11, 2006 | 01:32 PM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
new exhuast
hi all ive fitted my new exhaust replaced the two cats and put a 3 inc free flowing silencer from the y pipe which dumps by the diff my question is now when i plant the throtal theres hardly any tyre spin smoke is it possible the turq cure has moved up the reve range as im still getting o-60 time in 6sec it cant be down on power could it any ideas
Old Aug 11, 2006 | 01:36 PM
'86 350's Avatar
Car: '86 Camaro SC
Wow.... I have no idea what the hell you said.
Old Aug 11, 2006 | 02:03 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Translation:
Hello all, I have fitted my new exhaust and replaced the two cats with two 3 inch free flowing silencers from the y pipe which dumps by the differential. My question is now when I plant the throttle there is hardly any tire spin/smoke is it possible the torque curve has moved up in the RPM range because I’m still getting 0-60 time in 6 seconds. I hope I did not loose any power with this mod, any ideas.
Old Aug 11, 2006 | 02:53 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Did you replace only the cats?
Old Aug 11, 2006 | 10:05 PM
C&DPerformance's Avatar
Car: 89 Formula 350
Engine: 355
Sound like you killed the bottom end by putting to big of exhaust on it. If you only got 2 3" pipes that dump in front of the axle it's like running open headers.
Old Aug 12, 2006 | 06:37 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
no i replaced the cats with same diameter pipes two and half inch then put a simmons silencer on the end of the y pipe with 3 inch inlet,outlet 24 inch long which ends just in front of the diff sorry my spelling is crap,so if i move the silencer to the back of the car and run 3 inch pipe to it would that make a difference i just love smokeing them tyres
Old Aug 12, 2006 | 10:54 AM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well eliminating the cats alone isn't going to make much of a difference in performance. And I'm not sure what a "silencer" is but it sounds a lot like a muffler. And if it is, moving it back won't make much difference, if any.
Old Aug 12, 2006 | 11:03 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
sorry yes a silencer is a muffler
Old Aug 12, 2006 | 11:52 AM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
well just pull of the silencer and see if your back to tire smokin again,id just run it with cats only, sound good to me,i mean if you gotta run the cats lol
Old Aug 12, 2006 | 01:22 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I think he said he got rid of the cats already, so he would have to put them back on if he wanted to run just cats.
Old Aug 12, 2006 | 02:35 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
we have to have at least one muffler on are cars here not including cats and it has to finish past the back of the door and we dont have to have cats or any emmisions equip on cars made before aug 1992
Old Aug 13, 2006 | 12:08 AM
stroker_SS's Avatar
Engine: 355
What engine do you have, and is it in good tune, make sure you didn't bump any sensors(o2) and break the wires. I doubt your exhaust would have much to do with the power"loss". And if you still want to burn tires and all else fails just put your old exhaust on.
Old Aug 13, 2006 | 08:47 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
ita a 5.7 tpi had new 02 sensor only code now is 36 maf burn of relay stuffed put old system back on last night to see if any difference there is it smokes the tyres better,now could it be some thing to do with back presure i only ask this cause some tuners over her think that autos need some back presure for first gear pull off or some think like that
Old Aug 13, 2006 | 12:08 PM
stroker_SS's Avatar
Engine: 355
Back pressure to pull off first gear? Tons of drag racers use autos with open headers. I guess you could do some chip burning to care of the no tire smoke problem with the new exhaust and take advantage of your new free flow exhuast, or if you like burning the tires that much, just leave on the old system.
Old Aug 14, 2006 | 09:17 PM
86 Tranni's Avatar
Car: 86 trans am
Engine: Lg4
what type of exhuast did you get?
Old Aug 15, 2006 | 10:50 AM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
dont have a specific system all i did was replace the 2 cats with pipes and put a simmons free flow muffler on witch is a 4 inc round with 3 inc inlet outlet it was for a twin turbo v6 granada that was rated at 400 hp
92firebirdguy
Sep 1, 2016 07:53 AM
BAK12484
Nov 20, 2001 06:31 PM
redcamaro83
Jul 24, 2001 08:41 PM
87firebird
Apr 22, 2001 06:26 PM
