big block header problems
Old Aug 19, 2006 | 04:38 PM
Duke901's Avatar
Car: 89 Formula
Well i got the passenger side header in, but now im having problems getting the motor to tilt or rise high enough to get the driver side in there. How did everyone else with big blocks put headers in. Thank you Mike
Old Aug 20, 2006 | 02:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Have you tried sliding it up from the bottom? What headers are you using?
Old Aug 20, 2006 | 02:19 PM
Duke901's Avatar
Car: 89 Formula
hooker swap headers for a big block, yes i have tried from the bottom, only way you can do it.
Old Aug 20, 2006 | 03:35 PM
amerikan_rhino's Avatar
They are needed to be installed before the engine drops in the bay and have them tied back again the inner fender wells (I know its a 2-3 man process and more fo a beat on install then a bolt on)
Old Aug 20, 2006 | 03:49 PM
Duke901's Avatar
Car: 89 Formula
Ya i already beat the floor on the passenger side, So i guess now i got to take it back off and raise the motor.
Old Aug 23, 2006 | 08:57 PM
Duke901's Avatar
Car: 89 Formula
Well i tried to put in the driver side header today, i raised the motor and the header still didnt want to fit right. It looks like i have to cut the pinch weld where the header bends to go under the rocker. Does everyone have the much trouble.
Old Aug 23, 2006 | 09:16 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
To what I've read regarding the swap headers , they are a pain in the **** to install. I can't believe I haven't even gotten that far with my project which started in Feb. '06 It has taken to long but it's coming.
Old Sep 8, 2006 | 02:28 PM
maxrochatansky's Avatar
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
Axle/Gears: 10 bolt 3.42
hey guys , how are you doing with those hooker headers ? i still have my 454 sitting in the shed. it came with some long-tube truck headers. if those hookers fit THAT bad, i might as well take my chances with the truck headers.
does anyone have any PICTURES of their install ?????? thx
Old Oct 23, 2006 | 08:02 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
how much work is it to actually get these things in? are you talking about cutting and banging in metal or just a few minor mods to get them to fit?
Old Oct 24, 2006 | 10:18 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
If you have the instructions for them you do have to grind the pinch weld on the drivers side for clearance. When I put mine in the passenger side to about 10 times as long to install and the drivers side went in pretty easy.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
evilstuie
Feb 28, 2016 03:33 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
