Stage 8 Header Bolts
Old Mar 11, 2007 | 10:35 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I'm putting headers on on my '86 iroc (LG4) its hard to say what length bolts I need because most of them are different lengths. I was thinking 1" bolts. Do i have to modify the power steering bracket as well as the A/C braket to make the headers work?
Old Mar 12, 2007 | 11:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1" will probably be too long unless the headers you decide to use have thick flanges. 3/4" would be more like it.
Old Mar 12, 2007 | 01:12 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Make sure you use stainless steel bolts too. You may have to modify brackets in order for them to fit. With my Hooker 2460's I had to do some SLIGHT modification (no welding )
Old Mar 12, 2007 | 10:38 PM
86irocu's Avatar
Car: 1986 Iroc-Z
how thick would you say they would have to be to use 1" bolts?
Old Mar 12, 2007 | 10:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably about 1/4". If they're too long they'll bottom out in the heads before they're tight.
Old Mar 13, 2007 | 01:47 PM
86irocu's Avatar
Car: 1986 Iroc-Z
So the 3/4" stage 8 locking head bolts are the way to go?
Old Mar 13, 2007 | 01:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably, yes.
Old Mar 13, 2007 | 03:42 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I found the Stage 8 bolts a PIA to work with. Maybe because I have 1 3/4" headers but the clips were tough to get on. I do like the allen wrench hole in the center. Makes it easy to get the bolt snug.
Old Mar 13, 2007 | 03:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On some headers you may need to file the clips a little to get them to fit.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
toronto formula
Nov 10, 2015 06:17 AM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
