how restrictive??
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: how restrictive??
You don't have stock headers, you have stock manifolds. They're not completely unfortunate as far as manifolds go, but they're vastly inferior to headers.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ok and one last thing. i searched on the forums but didnt find much. shorty headers give u more back pressure than full length one corrct? with that said do u get more torgue with shorties and less hp? and one last thing do we not lose any torque with full length headers?
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Pretty much with any more free flowing in the exhaust system is going to lose a little bit of torque but gain a little bit of hp, not even sure if it is enough to notice.
Engine: 383 Carb
Transmission: 4L60
Horsepower and torque are really just two sides of the same coin, so you can't really say that you gain one and lose the other.
A larger diameter primary will make peak torque at a higher RPM than a smaller diamerter. A longer primary tube will also make peak torque at a higher RPM than a shorter one, but the effect isn't as pronounced as the effect of the diameter. Collector diameter and length also plays a part.
In the real world though, there are fitment concerns to worry about, so compromises are made, like the varying lengths of the primary tubes. If you're not designing your own headers, you just have to choose from what's available on the market.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i understand that. thanx alot for the help. i guess im gonna have to wait and save my bux for the long tubers
Engine: 383 Carb
Transmission: 4L60
There are a lot of disadvantages to long tubes, like reduced ground clearance, and the annoyance of custom fitting a complete exhaust system around the frame of a car that was never intended to have long tubes installed in it. They're also probably unnecessary if you're going to be keeping the TPI. I'd just get a good set of shorties with a good Y pipe and call it a day.
My 84 is my race car that sees limited street use, and it has long tubes. My 88 is just a cruiser and it still has the stock manifolds, but if I ever put headers on it, they'll just be shorties.
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ya my 88 is my driver and my racer. im gonna be buildin a 383 once a start college. i guess i can buy headers then. so shortie im lookin to see 10-15 horse gain?? plz tell me im lucky. lol and also i was recommended to use the shorties u can buy at autozone. idk but they seem ok.
Engine: 383 Carb
Transmission: 4L60
Maybe even more than that, depending on what the rest of your exhaust system is like.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
free flowing 3in exhaust. umm single to dualie out. no cats either
