Edelbrock TES headers clearance questions
How tight are the Edelbrock TES headers for room under third gen f body cars? I'm worried that I can't get the oil filter and drain plug off with the headers installed. Do you have room to do an oil change without trouble or any other under car work?
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: Edelbrock TES headers clearance questions
i have these headers and there is absoloutely no problem doin ne of that, but i think u could say the same for ne other set of headers as i ve never heard of them restricting the drain plug or filter
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
That isn't where they are tight...thank god. They are a tight fit though....but any header is a tight fit on our cars!!
Car: 1989 Camaro RS
There is no problem doing oil changes, but there is one spark plug, i can't remember which one off the top of my head, that is almost impossible to get to.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I used a spark plug socket shortened at both ends to access the #1 plug. When AC Delco lengthened the stock plug, without changing the part number, I had to use the modified socket on all 8 plugs. No other clearance problems, though.
Bill
Bill
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I found that a gear drive ratchet and 5/8 pass-through socket works well also. No clearance issues since the plug passes through the ratchet and socket.
Car: 89 WS6 FORMULA
Engine: LB9 305
Axle/Gears: 2:73 posi
what kind of luck have you guys had with these headers,I like the look but others have said the tes aren't worth the money,and I should go with the hooker2055's.whats your opinions on this.thanks....fred.
Car: 92 Trans Am
Transmission: 4L60
I don't have enough time on mine to tell you much. They do fit tight though! I do need to do some more "negotiating" to stop some rattles.
