Header ID
Old Nov 9, 2007 | 02:48 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Header ID
is there a way to identify the headers on my car? Also what is a good header gasket to run...I currently have mr gaskets on now but one is leaking.
Old Nov 9, 2007 | 03:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Header ID
Have you got a picture of them?
Old Nov 9, 2007 | 03:15 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Header ID
I dont actually.. but I'm heading up to the place its stored at tonight to finish covering it up so I'll take some pics tonight and see if I can see any numbers anywheres.
Old Nov 9, 2007 | 04:56 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Header ID
Header ID-hpim0349.jpg this was the best picture I could get...I did get some numbers off them but they dont match any on the summit or jegs site the numbers are 012 then under them was 0497 so I have no clue what I have. any help would be great if you can find anything.
Old Nov 9, 2007 | 05:03 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Re: Header ID
Lookin' like Dynomax to me. They should be 1.5" primary tubes into 2.5" collector shorties.
Old Nov 9, 2007 | 05:04 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Header ID
they any good?...they look like crap i was thinking on painting them then wrapping them? good or bad idea?
Old Nov 9, 2007 | 05:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Header ID
They're not great, but they're better than stock manifolds. Header wrap is rarely a good idea.
Old Nov 9, 2007 | 06:47 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Header ID
Ran the numbers on the dynomax site and came up with nothing so I have no idea what these things are but they will have to do till next winters modding start cause this year is trans repair and carb rebuild and new air cleaner and other little things. thanks for giving it a shot tho..not sure on which header Im gonna go with but it will ethier be hooker or headman thanks to the sticky at the top.
Old Nov 9, 2007 | 07:30 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Re: Header ID
Don't limit yourself to those if you're not scared to drop a couple of bones and want some long tubes. Hooker and Hedman are pretty good choices for shorties, since SLP chopped their thirdgen line. I agree on the header wrap; I've seen pics on this site of headers that rusted through due to the header wrap absorbing water.
'Better than manifolds' (as far as performance) was going to be my response on those dynomax's as well. The reason I say they look like dynomax is because those are the only ones I've seen that have that loop on the header flange (except maybe Summit brand, but those are just reboxed from other manufacturers).
Personally, I drool over those Stainless Works and Doug's long tubes. But then again, they are about twice the price of my Hooker 2055s. Actaully Doug's aren't too bad at about $500.
Old Nov 10, 2007 | 05:10 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: Header ID
must be nice...here where I am I can't find a set of shorties for under 800 bucks....by the way whats to be had by going with longs tubes over shorties? I like the ceramic coating but I've herd bad things about them chipping but I've herd the painted ones rust out.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
