Hooker 2055's?
Old Nov 24, 2007 | 04:35 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Hooker 2055's?
I have a 1991 Z and was about to pull the trigger on the 2055's.. I am being to ld they do not fit my car.
Is there another addition for the 91-92's?
Old Nov 24, 2007 | 04:41 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Hooker 2055's?
That's because you need these:
Old Nov 24, 2007 | 04:56 PM
goomaan's Avatar
Car: 1987 IROC-Z
Re: Hooker 2055's?
And these are?
Old Nov 24, 2007 | 05:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Hooker 2055's?
Who's telling you they won't fit your car?
Old Nov 24, 2007 | 05:02 PM
goomaan's Avatar
Car: 1987 IROC-Z
Re: Hooker 2055's?
The hooker and summit sites. Plus my mechanic who is going to install them for me. They are recommending HOK-16767HKR with HOK-2460-2HKR .
Old Nov 24, 2007 | 05:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Hooker 2055's?
2460s are made out of heavier gauge stainless steel, and don't normally come with AIR tubes. 2055s should fit your car fine if you have a 3" single cat.
Old Nov 24, 2007 | 11:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Hooker 2055's?
Those are Dyno Don's custom headers. Those are the only ones that work with dual cats. The other companies stopped making dual-cat headers.
Old Nov 25, 2007 | 11:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not completely true. Hedman 68491, $365.95 from Summit (the picture and application button info are screwed up on summitracing.com).
If your '91 is single cat, it'll be the small 2-1/4" one. The 2055HKR pipe to the cat is 3". '86-'90 TPI single cat application cat & cat-back will fit the chassis just fine (might have to alter a hanger or two).
Old Nov 26, 2007 | 08:28 PM
goomaan's Avatar
Car: 1987 IROC-Z
Re: Hooker 2055's?
I have a single cat system with the Borla Cat back exhaust. I have no problem changing the cat to handle the 3".
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
