long tubes *budget*
Old Jan 9, 2008 | 07:29 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
long tubes *budget*
whats the best long tube for someone on a budget? i saw the hedmans for like 150 in summit and saw the hooker long tubes for like 500, are the hedmans alright? whats the big advantage to the hookers? how well do each of these fit?
Old Jan 9, 2008 | 07:57 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: long tubes *budget*
Budget = headmans only diff is hookers are 1 3/4 primary and headman are 1 5/8 primary for most street aplicatons the 1 5/8 will be great.
Old Jan 9, 2008 | 10:08 PM
Car: 85 camaro
Axle/Gears: 342
do the hedmans have the nice thick flange? or the 1/4 flange? also if anyones running these how well do they fit? what are some of the clearance issue spots?
Old Jan 9, 2008 | 11:13 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
https://www.thirdgen.org/forums/exha...int-gonna.html pics of true dual
Here is what MW66NOVA said...
the only thing that you may have a problem is the lower control arm in
the front hits the header primaries and i want to say #3 primary hits
the cross member. solution: make a small dent in #3 primary to clear
crossmember, take hack saw to lower control arm perch. really easy and
the install from the top (mine did anyhow). if you can weld, or know
someone who can, you can fab up a y-pipe in no time
Last edited by 89formula350b2l; Jan 9, 2008 at 11:15 PM. Reason: Automerged Doublepost
Old Jan 10, 2008 | 05:46 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I went with hedmans. You have to do some massaging and creative work-arounds but it's nothing any worse than Hookers (See the sticky for the 20 something long list of things you have to do....)
You can see here how close the primary gets to the k-member.
And here you can see how close the collector gets to the A-arm perch in question.
Old Jan 10, 2008 | 09:58 AM
Car: 85 camaro
Axle/Gears: 342
thanks for the pics guys... so if i work those few areas to clear, i can have a decent set of long tubes for about 150, and i have an exhaust shop ready to do me a full header back true dual exhaust for about 200 bucks, thats for aluminized steel, but for that price, if it rusts thought, ill have him put another on
so does that sound like a fair price?
anyone found the hedmans for cheaper than summit at about 150?
Old Jan 12, 2008 | 01:57 PM
Car: 92 Camaro
Axle/Gears: S60 373
You can try ebay. However I think the Hedman Longtubes are a good deal and alot of members here are running them. I think even wtih my power I might still go with the 1 5/8 LT's.
Old Jan 13, 2008 | 10:02 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I had the hedman long tubes in my 89 and my 87, the 89 I put a carbd 355 in with poly motor mounts, so the headers went in completly painless (at the same time the motor went in), the 87 however was stock, and the motor mounts were old and worn out, so I ended up having to lift the motor up a little to squeeze them in, but with a little bit of work, they went in relativly easy. Next thirdgen I get is definatly getting them too!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
