dumps before the axle?
Old Feb 7, 2008 | 10:22 AM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
i just wanted to hear from people that actually have duals with dumps before the rear axle, im thinking of this for my new setup, any my car is a hard top car, my question is at a long red light or something, how bad will i smell exhaust? i know it wont like fill the car up or anything but will it be enough to notice over normal tail pipes? thanks guys
Old Feb 7, 2008 | 11:09 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: dumps before the axle?
i can't speak from experience...you may notice a difference, but i highly suggest checking local laws...i've heard stories of spending a couple hundred on a dump before the wheel setup and then they had to have it re-done propoerly to pass inspection. Just a heads up.
Old Feb 7, 2008 | 12:18 PM
Pocket's Avatar
Car: 91 Trans Am
Mine dump before the rear axle
Ive never had a problem with fumes
If you have rust issues, you may want to reconsider thou
Also, if you do this, aim the dump at the ground. If you leave it strait the interior of the car will resonate and it will sound incredibly loud and unpleasant
Old Feb 7, 2008 | 04:33 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Hell my system wasnt even completely welded for a while on my car and I never had any problems with fumes at all. I mean I guess if you sit inside a garage with the exhaust facing towards the wall it might be a problem, but that's not any different than any other exhaust.
There's lots of drawbacks to dual exhausts, but fumes definitely werent one of them for me.
Old Feb 7, 2008 | 05:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Fumes are a drawback if you are running a carb car with a big cam and have to have the idle a little fat. I wouldn't do dumps again on a really big cam'd car and would run them out the back instead.
Old Feb 7, 2008 | 08:42 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i can agree with ya on the fumes with a carbed engine
Old Feb 7, 2008 | 09:58 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I've heard people that have developed severe rust issues aft of the dumps, over a period of time.
Old Feb 7, 2008 | 10:20 PM
Pocket's Avatar
Car: 91 Trans Am
Mines been there for almost a year and a half daily driven
No rust
What would make you think it would cause that?
Old Feb 7, 2008 | 10:55 PM
Stephen's Avatar
Car: 87 GTA
I would think aiming at the ground, would INCREASE the noise, being confined under the car.
Rather than shooting it off to the side or straight back, which I think would be quieter inside the car.
Old Feb 7, 2008 | 11:44 PM
Pocket's Avatar
Car: 91 Trans Am
I ran it strait out of the cherry bomb for about a month, sounded horrible
Went back and had a turn down made. Lots quieter inside
Old Feb 8, 2008 | 09:11 PM
stroker_SS's Avatar
Engine: 355
No rust
Well, when anything is burned a large amount of steam is created, plus the large amount of heat dumped under the car will also extremely accelerate the corrosion caused from the steam that gets into every crevice of the underbody. Don't take my word for it, i'm just telling you what i've heard.
Old Feb 8, 2008 | 09:39 PM
Pocket's Avatar
Car: 91 Trans Am
Not the first spit of rust and I was under there about 4 weeks ago messing with the trans
Old Feb 8, 2008 | 11:29 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
then to prevent rust.....can you dump it before the axle but close to a side exit?
im looking to get a single chambered tube exhaust from summit racing
Old Feb 9, 2008 | 10:08 AM
stroker_SS's Avatar
Engine: 355
Side exit exhausts will rust chrome wheels, but again im goin on hearsay.
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
