Spark plug changes
Old Mar 14, 2008 | 08:43 PM
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
Spark plug changes
I have a 88 IROC with a 305 in it. It has Edelbrock headers. Some of the plugs are blocked by the header tubes. Is there a way to get the plugs out without removing the header?.............Do any of the header bolts go into a water jacket?
Mike
Old Mar 14, 2008 | 10:01 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: Spark plug changes
i have the edelbrock headers and dont use water jackets....however i get to some of the spark plugs by ussing a wrench loosening them up and then taking them off by hand
Old Mar 14, 2008 | 10:05 PM
ljnowell's Avatar
try from underneath. Use s spark plug socket with a wrench, alternate with ratchet. Cuss a little. Then maybe if you have to cut the socket down for more clearance, so the plug can slide through, and use a wrench on it somemore. Then when they are done, drink.
Old Mar 15, 2008 | 09:12 AM
grizzlyta44's Avatar
Car: 1986 Trans AM
Engine: 305ci tpi
Axle/Gears: 2.77 Borg Warner
Had the same problem, Jack that bad boy up and go from the bottom, it should give you a clear shot at the rest of the plugs
Old Mar 15, 2008 | 12:53 PM
GT150's Avatar
Car: 1988 IROC-Z
Thanks for the advice, I liked the "drink alot" the best.............
Mike............ ...........
Old Mar 15, 2008 | 02:09 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I know where you're coming from...I bought this and it made my 3hr spark plug changes with headers, back down to the usual 30min... good luck
Old Mar 15, 2008 | 03:10 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Hmm...looks easy enough to make out of a standard spark plug socket. Just 10minutes or so at the grinding wheel, if you dont mind modifying tools that is. That might help with my number 8 plug that I still havent changed, lol.
Old Mar 15, 2008 | 06:33 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, its a pretty simple tool. What they did is take the standard spark plug socket and shortened and drilled out the "socket" part so the plug will fit all the way through. If I had the macheniery, I would have done it on my own, but its ok, its only $13 with ship. I think the "special" SLP version is like $45 from Jegs/Summit?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
