problem after header install
Old Mar 17, 2008 | 08:58 PM
TorqueTilla's Avatar
Car: 1991 camaro rs
Engine: 305tbi with mods
Transmission: t-5
Axle/Gears: 3.08
i just got my car back today from the shop, i got hedman headers put on along w a catco cat and hooker catback, theres a serious problem, the car actually feels slower then wen i didnt have headers! idont get. I only have 2 guess's one being that since my pulley didnt come in the mail yet i have a big exhaust leak since all a.i.r functions got deleted or the other one is that i have a radiator leak and my cars just too hot? ne ideas would help, i was very dissapointed when i got my car back.
Old Mar 17, 2008 | 09:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: problem after header install
are the air connections plugged? it may be causing a big vaccum leak
Old Mar 17, 2008 | 09:54 PM
Car: 1991 camaro rs
Transmission: t-5
Axle/Gears: 3.08
i didnt even think of that lol, where are all the air connections i should check?
Old Mar 17, 2008 | 10:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its been sooooo long since my car had the air tubes....
each side of the engine has a tube, with the 4 little tubes one for each cylinder. Those larger tubes connect to something, the carb or some pollution control and if they are just left open i think they could be causing a computer issue or vacuum leak.
Are the air tubes still hangin around on the motor or what? pic?
Old Mar 17, 2008 | 11:16 PM
Stevo's Avatar
Car: Pair of 92 Z28s
You would know, you would have a loud exhaust leak.
Talk to the shop who installed them...they removed some of the spark plug wires make sure they are not crossed. Just check some of the obvious stuff out.
What pulley are we talking about in the mail? Radiator leak? Is the car running hot or not check the gauge and tell us what it reads, yes if its running 240* you will notice a drop in performance.
Old Mar 18, 2008 | 10:53 AM
Car: 1991 camaro rs
Transmission: t-5
Axle/Gears: 3.08
the smog pump delete pulley from gmpartsdirect, as far as the temp goes, it shows the engine temp beyond the red area, but i notice no smoke comming from the engine or nething, im gonna plug up the air tubes today, what should i use to plug them?
Old Mar 18, 2008 | 12:41 PM
ljnowell's Avatar
There should be no vacuum leak. The air pump pumps air into those tubes. Sounds like a good case of messed plug wires. Could even be that when they were pulling them they messed some of them up. I would check there first. Anything within the proximity of the headers.
Old Mar 18, 2008 | 02:24 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
I did'nt know GM had a smog pump delete pulley!! Can you give me the part#, please?
Old Mar 18, 2008 | 03:28 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
How about you stop driving your car until you figure that out? If you are running your engine way up in temp you are going to destroy it
Old Mar 18, 2008 | 05:28 PM
danandamy's Avatar
Car: 86 Camaro
I'm betting the temp sender wire got against the headers and melted (thus the gauge pegged). You also need to watch your fan switch wire it will definitly get against your headers. Wonder if a plug wire got against your headers as well. In short I'd start with getting under the hood and going over everything that could get damaged by getting against the headers with a fine tooth comb, they get waaaaay hotter than manifolds do.
Old Mar 18, 2008 | 11:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is your SES light coming on?
Did they install and hook up the O2 sensor? (assuming you still have a computer system)
Most likely is they didn't get the ignition hooked back up properly (broke a spark plug, crossed some spark plug wires, plug wires shorted to the headers, etc.).
Old Mar 19, 2008 | 07:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Modern Day Muscle carries it. It also come on the GM serpentine conversion kit (you might look for part numbers there).
JamesC
Old Mar 19, 2008 | 09:28 PM
Car: 1991 camaro rs
Transmission: t-5
Axle/Gears: 3.08
well it seems my o2 sensor is connected and working, my mechanic said the air pump is basically wide open so im guessing i have apretty bad exhaust leak,also my radiator is blown so i picked up a new one and im putting it in tomorrow, i hope i can find whats wrong!
Old Mar 30, 2008 | 04:57 PM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Updates??????????????????????
rocn7roc
Sep 21, 2021 02:16 PM
Wesly_66
Aug 26, 2015 09:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
drathaar907
Aug 6, 2015 04:20 PM
