Which header to choose?
Old Mar 25, 2008 | 09:53 PM
misterchief's Avatar
Car: 90 Formula WS6
Engine: 5.7 350 ci
Transmission: 4sp Auto
Axle/Gears: 3.45 posi
I'm looking to change my exhaust in the coming weeks and I have two different choices to choose from:I'm installing the headers on a 90 Firebird Formula 5.7L. I would like to know if there are any installation issues with either or any other advice. If you prefer one over the other or if you have gone with one over the other let me know. Thanks
Old Mar 25, 2008 | 10:14 PM
Demon_Eater's Avatar
Car: 91 Camaro RS
Re: Which header to choose?
I would go with headman headers with my opinion, but why long tube headers?
Old Mar 25, 2008 | 10:24 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
why not
Old Mar 25, 2008 | 10:26 PM
Car: 91 Camaro RS
-shrug- I dont know I guess, I would just think shorties would be better, bet everyone's opinion is different. I seen it said on summit those are shorties :-|
Old Mar 26, 2008 | 04:12 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Most people go with shorties because of ground clearance.Just something to consider,you don't want to messup your new headers on the first speed bump you come across.
Old Mar 26, 2008 | 04:38 PM
Car: 90 Formula WS6
Engine: 5.7 350 ci
i've already taken that into consideration, and there are very few speed bumps or anything to worry about where i live
Old Mar 27, 2008 | 08:30 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have hedman long tubes. If your gonna shells out some money might as well do it once and buy the coated ones because the painted ones will just rust on you. These are what I have on my car.
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 27, 2008 | 11:15 AM
Car: 90 Formula WS6
Engine: 5.7 350 ci
did you have any problems installing these on your car?
Old Mar 27, 2008 | 11:30 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I had a clearance problem on both sides of the car where the headers hit the frame.It wasnt a big deal just heated the frame a bit dented it where I need them to clear and its was all said and done. Clearance issues are hit and miss with all are cars.What happened to me may not happen to you.
Old Mar 27, 2008 | 11:32 AM
Car: 90 Formula WS6
Engine: 5.7 350 ci
ok good to know
Old Mar 27, 2008 | 02:49 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
I would suggest these for you:
Dynomax 86001
Reason:
- Better collector design for more power. The choked collectors make less
power (HED-68460).
- Coated will last much longer and look better. Painted will flake and rust
within a couple of weeks.
You might also want to try Hooker Competition. They dyno well, and are
reasonable price.
Old Mar 27, 2008 | 10:15 PM
92RS702's Avatar
Car: 92RS
In that case,I'd agree with lukn4tbrl check out the hookers competition,good flow ,reasonable price,good fit,and in their price range one of the best in my opinion.
Old Mar 27, 2008 | 10:48 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Dynomax 86001
Reason:
power (HED-68460).
reasonable price.
Those dynomax headers are for 2nd gen Camaros.
The dynomax headers in the original post only have 1.5 inch primaries.
I like the Hedmans personally, but that's just me. And for how much they cost, you can afford to replace them when tehy rust out in 5-10 years, since replacing them costs less than a coated set.
Old Mar 27, 2008 | 11:28 PM
Car: 90 Formula WS6
Engine: 5.7 350 ci
^^agreed....plus its not like headman's are horrible or anything like that, just a matter of personal choice and how much money you're willing to spend
Old Mar 28, 2008 | 07:17 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
My mistake on the type error; I was looking at port size/spacing and bolt patterns.
I do however strongly suggest something coated. Even the headers that
84Z28 is suggesting are better. They have thicker flanges which will reduce the chance of warping and an exhaust leak at the port.
At least try to find something with a smooth, tapered collector. It will make
more power.
Good luck in your search.
Old Mar 28, 2008 | 11:24 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
My opinion would be to buy a set of dyno dons 1 3/4 shorties with a y-pipe. These fit perfect and come coated. Why hassle with denting in your car for long tubes, and possibly having to move components around to facilitate your new headers. The 1 3/4 with 2.5 collector is enough header for the average build, and they cost 600 coated with the y-pipe from dyno don. Look him up, these have absolutely no clearance probs!
Just my
If you look at my sig, I am only going with 1 3/4 shorties and making 470 horse
Old Mar 28, 2008 | 04:03 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
There is no need for a 1-3/4 header unless your making the car for the track and want it to flow a ton. 1-5/8 header is plenty for a street car and will keep the power band down low where it needs to be for the street.
Old Jul 4, 2009 | 01:33 PM
Rattlesnake92's Avatar
Car: 1992 Formula Firebird
Engine: TPI 350
Axle/Gears: Aussie 3:70 rear
I have a 1992 formula with a TPI 350, current free flow exhaust into a Cherrybomb Vortex muffler. I want to add headers but do not know which 1's to get. I cant have longtube, clearance issues, I'd rather have shorty headers. Which brand should I choose? Stuck on this subject, need HELP...Rattlesnake92
Old Jul 4, 2009 | 08:16 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Hooker 2055's are probably the best shorties you can get, along with dyno don's custom made headers.
http://www.jegs.com/i/Hooker/520/2055/10002/-1#
Old Jul 4, 2009 | 11:30 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Hookers all the way
Old Jul 5, 2009 | 07:24 AM
Engine: TPI 350
I heard alot of good things about hooker, the link that I was sent was for a 90'. Mine is a 92 TPI 350, will those fit? And if so, only thing I need is headers, my exhaust guy can fab the rest so he recomended I goto this site for questions. 1 more thing, in upgrading my ignition, my car is relatively stock except the exhaust. What upgrades would anyone recomend that would fit my car ignition wise and maybe Computer chip wise? Its an everyday driver with 186,550 miles.
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Chad Speier
Sep 24, 2015 12:32 PM
