Manifold plugs?
Old Apr 23, 2008 | 01:26 PM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Manifold plugs?
Ok guys so I got my delete pulley and Im ready to take my air pump off but I dont want to crimp the tubes to the manifolds incase I ever have to put them back on. Is there a certain kind of plug that I need to use to plug up the manifold holes? I was thinking I could use something like this. Would that work?
Old Apr 23, 2008 | 02:16 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Manifold plugs?
If the plug fits, why not? The check valve should prevent exhaust from back flowing if you want to or need to leave the air tubes attached to the manifolds. Those manifold fittings are hard to get off without damage..
Good luck!
Old Apr 23, 2008 | 02:58 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Re: Manifold plugs?
That should work. I remember a while back someone did that same thing and i think they were 1/4 inch plugs. Get yourself some penitrating oil, when the engine is cool of course, and let them soak. The air tubes should come off no problem. Good luck!
Old Apr 23, 2008 | 04:03 PM
Shadowman's Avatar
Engine: 305 TBI
Re: Manifold plugs?
Thanks for the replies guys. Ill try it out.
Old Apr 23, 2008 | 04:41 PM
Stephen's Avatar
Car: 87 GTA
Re: Manifold plugs?
1/4" NPT its & virtually them good.
Old Apr 23, 2008 | 04:54 PM
Shadowman's Avatar
Engine: 305 TBI
Re: Manifold plugs?
Whats 1/4 NPT and where can I get them?
Old Apr 23, 2008 | 05:10 PM
Stephen's Avatar
Car: 87 GTA
Re: Manifold plugs?
Thread size. Go to any Home Depot/Lowes/Tru Value, and they'll have them with all the nuts/screws/bolts.
Old Apr 23, 2008 | 05:11 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Manifold plugs?
any hardware store, home depot, lowes, fastenal....tell them u need male 1/4 npt plugs, NPT= National Pipe Tapered thread, its U.S. Standard tapered pipe thread sizes....
Old Apr 26, 2008 | 07:20 PM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: Manifold plugs?
If you want them flush,get the ones with a recessed hex head.The type you use a allen key with.
Alicat.
82tabird
Dec 21, 2015 10:22 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
anesthes
Aug 24, 2015 08:18 PM
camaroken83
Aug 10, 2015 11:35 AM
