Catalytic converters?
Old Apr 27, 2008 | 09:11 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Hi, well I have a 91 T/A L98 N10 (dual cats) car. Well It was suppose to have the dual cats, but now it has some hacked up y-pipe with no cats, well, I am putting in some hedman shorty headers, and need to get a new y-pipe made up. So I am going to put cats back in, to be all legal, and thats the only way an exhaust shop will touch it.
So, my question is, what do you think I should do? Put dual 2.5" high flow cats in? Or, Put a single 3" high flow cat in? The single 3" would be a cheaper way to go, but, I kind of want to run a cat, but I want performance also, I am not in an emissions state, but still am trying to be responsible.
Old Apr 27, 2008 | 10:26 PM
jem1975w's Avatar
Re: Catalytic converters?
a 5 gallon of latex paint put more toxin in the air then a full tank of a new taho does so do what is in ur budget
Old Apr 27, 2008 | 10:34 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Thanks for you helpful insight.
Like I said, an exhaust shop wont touch it, without putting cats on, and I dont mind putting cats on, because hell, these cars are not that fast anyways, and budget, well, one cat or two, that doesnt matter either. I just figure, If i am going to put a cat on, I want the best setup, I know the dual cats, are suppose to be a better way, but that is comparing stock dual cat, to a stock single cat setup, and the stock single cat is alot smaller than the 3" high flow one that I am looking at.
So, it's either (2) 2.5" high flow cats, or.
(1) 3" high flow cat
Old Apr 27, 2008 | 11:10 PM
MarkimusPrime's Avatar
If you can tuck em real nice, go for duals...but if you can't...might as well for for the single cat so you can hide it up in the bottom of the car. Just my opinion, anyway.
Old Apr 28, 2008 | 07:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, Catco makes a dual set-up. Search Summit.
JamesC
Old Apr 28, 2008 | 07:19 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
(thumbs up) for south dakota with no emissions
Old Apr 29, 2008 | 02:20 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Get a custom 2.5" mandrel-bent y-pipe with dual 2.5" Magnaflow cats put in. That setup works great for me.
Search the exhaust board for "dyno don headers" and you'll see the pics.
Old Apr 29, 2008 | 11:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hedman makes dual cat headers that include the pipes to the cats. Install cats where they're supposed to be, and you're there.
Old Apr 29, 2008 | 12:26 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
I searched for Dyno don headers, and found alot, but nothing with a dual cat setup. It sucks, no exhaust shop in this town, has a mandrel bender
I looked through hedman stuff, all I can find are 2 different y-pipes, but they are both single cat versions, only difference is 3 bolt flange vs. ball and socket.
Thanks for you good input guys, I think I will probably do a dual cat setup. But keep the input coming.
Old Apr 29, 2008 | 01:18 PM
five7kid's Avatar
They don't sell just the dual cat y-pipe, they sell them as a kit, headers and pipes. 68491, on www.summitracing.com HED-68491, $365.95. (Summit's description is correct, but their "Application" tab is hosed up.)
Probably less than you would pay to have someone fab pipes or modify your existing pipes to fit standard Hedman hedders.
Old May 2, 2008 | 02:36 AM
Kevin91Z's Avatar
https://www.thirdgen.org/forums/exha...aders-4in.html
In post #11 he has a pic of his dual cat and single cat y-pipes.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
