header sealing?
Old May 1, 2008 | 02:05 AM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
header sealing?
im having a huge problem sealing my new headers to my 305tpi camaro. I put on a set of mr gasket and they blew through, I was looking at summit and idk what to go with, There are round port primarie headers with D port cyl heads, do I get the gaskets that are D port or what? also if anyone can get a link where I can buy them I would appreciate it, thanks
Old May 8, 2008 | 07:23 PM
JohnC's Avatar
Car: 1988 IROC-Z
Re: header sealing?
Did you clean up the mating surface of the cylinder head before you put the headers on? Try cleaning them up with a wire brush and 180g sandpaper. Also try copper gaskets.
About what shape gaskets to get, I would get what matches the port on the head.
Old May 8, 2008 | 09:08 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: header sealing?
trying to seal to different style ports is going to be very difficult. either way you go your going to be blocking a portion of one of the ports off. try making a custom gasket. use some paper if you can and draw a template of what you need.
Old May 9, 2008 | 02:51 PM
Car: 86 Iroc-Z
Re: header sealing?
I think its D port, What ever a stock 86 tpi 305 has. I might just go with aluminum gaskets.
I took off the old gasket to see if it burned or not. Well it did, The exhuast blew out the side on the two outter cyl ports. i tried using a gasket that i knew worked on my 350 but it just leaked more. that one had the metal covered by the high temp paper?
Old May 11, 2008 | 12:57 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: header sealing?
i JUST dealing with the same issue, blew out paper gaskets, and a set of d-port coppers, went and bought mr. gasket copper round port gaskets, and bam! no more leaks
Old May 12, 2008 | 12:38 AM
Car: 86 Iroc-Z
Re: header sealing?
i just bought a set of square port aluminum percy seal for good gaskets, I hope itworks if not Ill just send them back to summit saying they didnt work lol. how did it blow out the D port coppers? is it a Dport head?
Old May 12, 2008 | 08:26 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: header sealing?
its a d port head, round port headers. it ddnt blow it out, but it leaked, like it never sealed at all. round port gaskets work perfectly
Old May 14, 2008 | 04:55 PM
Car: 86 Iroc-Z
Re: header sealing?
damn, Well ill try the ones I got and see what im gonna do from there. Damn things are 35 bucks a pop
Old May 14, 2008 | 05:55 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: header sealing?
i got a set of mr. gaskets for 37 (for the pair) at o'reilly
Old May 14, 2008 | 06:00 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Re: header sealing?
i got the copper gaskets from autozone and one side leaked right away... im not sure why... the only thing i can think of is that i put it on backwards but i am 90% sure i didnt. felpro last for a good amount of time.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
bamaboy0323
Sep 12, 2015 07:14 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
hdis2002
Sep 8, 2015 02:52 PM
