Hey guys, how do I run the 2 1/4" pipe from the cat over the rear end?
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I've got my old exhaust off, my new Flowmaster 80 series CrossFlow and tail pipes ready to mount. I just can't get that damn pipe over the rear end, how do I do it?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Hey guys, how do I run the 2 1/4" pipe from the cat over the rear end?
I am guessing you dont have the car up high enough if it is a actual flowmaster kit.
Engine: 2004 LQ4
nope. it's a stock pipe, but a flowmaster muffler..
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
if you mean you cant get the pipe of from over the rear youl have to cut it in the middle and i had to cut the hannger too get mine off
Engine: 2004 LQ4
That's how I got it off, but I have no clue how to get the new one back in..
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
well back before i got my exhaust on i was messing around under the car and fed it from the back up around and it went pretty easily BUT i didnt have taht ahnger there cause it was a 4th gen kit
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
You probably need access to a lift. I think thats why the 3" flowmaster systems have the I-pipe split before the axle...
Engine: 2004 LQ4
I did it.. My arms feel like jello, but it's up. I cut it right after the 90* bend that goes over the rear end, and jointed it back in with a 2 1/4 to 2 1/4 adapter. It sounds pretty good for a V6.. But I've got to take off a tail pipe and cut it shorter.. At a later date ofcourse..
1992 Trans Am
Aug 8, 2015 08:16 PM
