Dual 3.5inch exhaust with ground clearance?
Pics say it all. check em out let me know what you think.
Ive got a few more photos here: http://s36.photobucket.com/albums/e3...%20Turbo%20TA/ If you wanna check it out. The exhaust starts with 3.5inch round pipe then merges in to 3.5 oval and back to round to merge on to the mufflers. The last photo shows how we had to cut the passenger side floor boards for more clearance but it all still fits under the passenger seat with modifacation to only one of the seat mountes.
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: Dual 3.5inch exhaust with ground clearance?
look at dem sewer pipes!!! looks nicely done though
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well I see your exhaust wont be a problem for your 1000+ HP goal, nicely done!!
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Very nice work.
What tubular K-member are you using? How is the craftsman ship on it? Thanks, Allen
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what fuel tank are you using?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
looks good. thats an easier setup to do with shorty headers... if you had longtubes it be harder to bring the pipes back over to the passenger side
looks good tho.
looks good tho.
Car: 89 Iroc-z
Transmission: TH400
that would explain the pipes in that arrangement tho. very nice
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
would also explain the beastly fuel system too! nicely done. looks like no expense has been spared with that beauty!
wow....
You should post a video of your exhaust, I wanna hear it.
//<86TA>\\ what fuel tank are you using?
Orr89RocZ looks good. thats an easier setup to do with shorty headers... if you had longtubes it be harder to bring the pipes back over to the passenger side
looks good tho.
looks good tho.
Car: 1989 GTA
Engine: 369 TPI
Thanks. I'm looking at the Racecraft road race K-member because it does have extra bracing.
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Nice set up. Are you taking out the passenger seat for good, or making a new mounting bracket for it?
downsouthboy
Aug 29, 2015 11:29 AM
