Torq specs for headers
Old Oct 8, 2008 | 04:15 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
I'm installing headers next week and can't find anything on torq specs...anyone know what it would be for Hooker headers?
Old Oct 8, 2008 | 05:44 AM
92vertz28's Avatar
Re: Torq specs for headers
Its 26 lb ft for stock manifolds....No reason to think that it isn't the same for headers
Old Oct 8, 2008 | 09:21 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Are you using the 2055s? wat kind of cat back? Reason im asking i got a LB9 5 speed aswell and want to know what people are running on there LB9
Old Oct 8, 2008 | 11:46 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
as tight as frickin' possible with the pattern going from inside bolts outward...seriously...cause they'll still rattle their way loose.
Old Oct 9, 2008 | 01:14 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i agree, forget torque specs, u want those buggers to be on there [edited by Kevin91Z]. eventually they do work themselves loose unless you use those stage 8 non loosening fasteners. theyre kinda pricey for bolts but yeah just get them on really tight, theres nothing worse than having a nice ride and a horrible farting sound coming from your engine
Last edited by Kevin91Z; Oct 10, 2008 at 02:42 PM. Reason: removed profane comment
Old Oct 9, 2008 | 01:55 AM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
That was a little bit much, don't you think?
But they're all right. Make those things as tight as possible, and then re-tighten them again after driving for like 30 minutes to an hour. Keep checking them and tightening them for about a week after installing.
Last edited by Kevin91Z; Oct 10, 2008 at 02:42 PM. Reason: removed profane comment in quote
Old Oct 9, 2008 | 03:49 AM
Car: 89 T/A
Engine: LB9
All my emission equipment is gone, no cat (not mandatory here), I"m installing ceramic coated Hooker 2460's with modified Y-pipe also installing Magna Flow 3" catback part #16829.Just to be sure the bolts do not work themselves loose I ordered a box of Stage 8 bolts.
Thanks for the replies
Old Oct 9, 2008 | 06:41 AM
mw66nova's Avatar
Engine: 7.0L
honestly, the stage 8's work themselves loose overtime as well. they were already on my firebird's 2460's when i got the car...couldn't stand how hard they were to work with...off they came in favor of some cheapy header bolts that came with a set of hedmans...much happier with them and i can actually get to them and tighten them now.
Old Oct 15, 2008 | 01:00 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Would it be ok to use loc-tite on header bolts or would the heat make it useless?
Old Oct 15, 2008 | 03:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It wouldn't hurt anything, but it wouldn't help anything, either. The heat would make it useless.
Old Oct 15, 2008 | 10:10 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Since your emissions is gone have you thrown any codes? Or notice your engine running lean? Post up a sound clip if you can. Im lookin for a good sounding exhaust with or without imissions. Sorry im kind of hijacking i guess.
Old Oct 16, 2008 | 04:55 AM
Car: 89 T/A
Engine: LB9
I removed the emission system last year and have not thrown any codes.I will be installing the headers and catback the last week of Oct (vacation working on and under the car - does it get any better)!
As for a sound clip it might be kind of hard as I do not own a vidcam but will try to borrow one and post.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Chad Speier
Sep 24, 2015 12:32 PM
angel2794
Sep 8, 2015 06:22 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
