people with 2210's please look
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I'm having problem getting the passenger side slip tube to seal up and stop leaking where it sits in the header. I noticed that it really only sits in the header like a 1/16 of an inch. I RTV'd the crap out of it and put a clamp around it and havn't started it up yet. I hope it works because it's driving me nuts. Anyone have any similar experiences.
To be honest, the hole pass side 2210 is leakey all together. I've tried every gasket and I just RTV's that all up last night as well.
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: people with 2210's please look
I've always used anti-sieze on the slip tube and never had a problem. Sounds like yours may fit too loosely.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Does your car leave in the air like that on a low eleven pass? I have a simliar car and will be running a real similar combo. Hows the 350 trans from coan holding up?
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
something must be wrong, mine goes in a full inch at least, and rtv sealed it very nicely.
The coan trans lasted about 5 years and started to slip late last year, it lasted a long time and took a lot of abuse so I can't complain too much. But I was disappointed when it was taken apart to see that it was almost completly stock other than the valve body, I'm lucky that it lasted so long. Stock friction discs, stock sprag, ect...not good for a "competition series" trans in my opinion.
This time I had A&A build my trans and install a trans brake, I broke the trans on the first pass on the brake. I just got the car put back together when the race season ended so I don't have any good transbrake passes yet. Thankfully A&A stood behind their stuff and completly rebuilt it for free, excellent company to deal with considering the circumstances.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Don't worry, It's probably not the trans builders fault. T-350's are just un- predictable and not always the best trans for race use. I was just wondering about Coans because they advertise some stout turbo 350's and wanted to hear some opinions.
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Permatex ultra copper
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
as for the main gasket, I'm using a cruddy fel pro one now that I cut a little as to not restrict my flow. But I have also used copper ones, both without leaks. Make sure those bolts are tight, they like to back out.
Pac J
May 17, 2020 10:44 AM
MadOTC
Oct 13, 2015 04:46 PM
