determing if it has Cali. emissions or fed. emissions
Old Dec 25, 2008 | 07:25 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
i need a new egr for my 86 305 tpi iroc. lookin it up on Autozone there are 2 diff part #'s one for Cali. emissions and one for fed. emissions
http://www.autozone.com/addVehicleId...leSelected.htm
i do not have access to the car where i could take a pic of the old one.
it was built at Van Nuys.
should i check the rpo's or vin or something?
thanx!
Old Dec 25, 2008 | 09:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Underhood sticker.
This should probably be in Tech/General Engine instead of Exhaust.
Old Dec 26, 2008 | 03:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: determing if it has Cali. emissions or fed. emissions
As far as I know, the TPI cars were all built the exact same way, meaning there is no difference between CA emissions or Federal emissions. I dont know why Autozone lists two different part numbers, but I would look at both of them before I bought one.
Old Dec 26, 2008 | 06:14 PM
Car: 1986 IROC-Z28
ok thanx guys...
Old Dec 26, 2008 | 08:42 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
RPO codes are NB2 for California Emissions, and NA5 for Federal Emissions. But your profile says you live in Florida...
Being built in Van Nuys wouldn't have had anything to do with emissions. The determining factor was the state the car was built for.
TPIparts.net shows 3 different EGR valves used on TPI engines from '85-'92. None, however, are based on CA or Fed emissions, but simply on engine/year. And the only one shown for your car matches the Fed emission valve shown by AutoZone in your link.
http://tpiparts.net/82_92_emissions
Edit: well, the tpi site doesn't SAY yours is the same one as the Fed. It says yours is the same one as used on '87-'89 350 TPIs. And checking AutoZone for those 350s, they show only one valve, and it's the same one as the Fed they showed for your car. Clear as mud?
Old Dec 27, 2008 | 03:59 PM
Car: 1986 IROC-Z28
ok thanx.
sorry forgot to mention, i am a resident of maryland, where my car has failed emissions twice and my 2 year waiver is up in october 09. i go to college in fl.
Old Jan 12, 2020 | 09:56 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
I believe that the emissions is based off the year of the car not the engine.
so if you Camaro is a 1982, then you need to meet the standards for 1982, not for the 2016 engine that you put in the car.
Old Jan 12, 2020 | 10:46 PM
Drew's Avatar
@FlyDoc
See - https://www.thirdgen.org/forums/prob...ad-issues.html
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
