header gaskets...what type
Old Jan 12, 2009 | 10:53 AM
RckyRacr's Avatar
Has anyone used either the Earls or the Remflex header gaskets? And
if so would you use them again?
Carl
Old Jan 12, 2009 | 11:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: header gaskets...what type
Originally Posted by RckyRacr
Has anyone used either the Earls or the Remflex header gaskets? And if so would you use them again?
Welcome to TGO. I have no experience with the above, so I may be wasting your time with another suggestion: Fel-Pro (Jeg's p/n 375-1404). I would use Fel-Pro again.
JamesC
Old Jan 12, 2009 | 11:52 AM
RckyRacr's Avatar
Thanks,
I normally use the Felpro 1404, But they usually start to leak after a couple of
years or so. So, I was looking at maybe trying out some of the new header gasket technologies.
Old Jan 12, 2009 | 12:00 PM
JamesC's Avatar
I normally use the Felpro 1404, But they usually start to leak after a couple of years or so. So, I was looking at maybe trying out some of the new header gasket technologies.
I've been running the Fel-Pro above for quite some time without incident. Keep us posted on your discoveries.
JamesC
Old Jan 12, 2009 | 11:32 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I run Percys "Dead Soft" Aluminum. Multi-layer type, never had a problem. Just do the re torque as they heat cycle a few times.
Max,
Old Jan 13, 2009 | 01:26 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Earl's for the win! I use the D-shaped ones for an LT1 as they work with my Trick Flow heads. My dad Dyno Don has used them with his headers he sells as well, and even when a bolt fell out, they didnt blow out or leak.
Old Jan 13, 2009 | 02:15 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
ehh, i havent had much luck with the fail-pros. i found some graphite gaskets at my local speed shop, theyre about a quarter inch thick, and are completely graphite except for a little flexible grid at the center. and those gaskets have been great for some time now, i havent even retorqued them in a loooong time
Old Jan 14, 2009 | 02:45 AM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
i've always used Fel Pro exhaust manifold gaskets on all of my headers, in the last 10 years, i have had 2 failures, both of them were due to my error.
Old Jan 14, 2009 | 06:59 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have had good luck with mr.gasket copper gaskets . i feel a lot of failures are due to poor prep. work . clean & de-burr header flange . clean cylinder head mateing surface . use quality bolts , chase & clean threads , tighten & torque from center outwards in small steps . good luck .
Twin_Turbo
Mar 14, 2016 10:10 PM
Chad Speier
Sep 24, 2015 12:32 PM
Hello, Michael
Sep 11, 2015 01:10 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
