y pipe with a 5 speed
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
just wondering if anyone has some pics of a y pipe on a car with a 5 speed and shorty headers. with ground clearance at a minimum i can't figure out any way to run it
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: y pipe with a 5 speed
can be done will have to go out sat to get a picture.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I'd like to see a pic of this too as I will need to fab a y pipe after my V8 swap. I have shorties and a T5 as well.
send me your email i can't get pics to upload
thanks
thanks
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Hooker 2055's have a Y-Pipe that will work with a T-5
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That's what I run. Check the pic for clearance (which isn't a problem):
https://www.thirdgen.org/forums/atta...ase-y-pipe.jpg
https://www.thirdgen.org/forums/atta...please-cat.jpg
JamesC
JamesC
Transmission: t5
only problem is then i'd have to buy hooker headers i'm just going to build my own just wanted to see how it was ran. mine seems like it has less clearance between the k member and pan
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are you using a stock oil pan? Aftermarket pans dont fit or work as well with the y-pipe.
Transmission: t5
ya it's not stock i bent the old one trying to get it off. apparently the previous owner had a sealing problem and glued the crap out of it
Are you just not happy with what's available in the shorty headers that's leading you to build your own? Dyno Don's headers are the best on the market right now if you hadn't seen them and they come with a y-pipe. If you do build your own, I would try to make the tubes a bit longer for more of a mid-length or even a tri-y design to promote a stronger midrange. Should be worth a few more ponies. Good luck!
Transmission: t5
I have headers the only problem is i'm not sure what brand so i'm not positive what y pipe will fit so i just wanted to see how they were ran so i could build my own y pipe
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
well.. i can show you a picture of mine but its just with exhaust manifolds still on them... if you want me to
Take a pic of them and post. Especially of the flange. We might be able to figure out what you have. Have you at least measured them? You want at least an 1-5/8" header.
Car: 1992 Camaro RS
I'm in the same boat as the OP. I bought my headers at a swap meet and I know they will fit the engine, but don't know what Y-pipe goes with them so I was just going to fab my own. I'm gonna fab up the rest of the exhaust myself, so I figured the Y-pipe wouldn't add that much work.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Hooker 2055's Y Pipe and T 5 Tranny...
Raf
Raf
86CamaroDan
Sep 29, 2015 10:08 PM
