y pipe question
Old Feb 12, 2009 | 11:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
y pipe question
I am about to buy some edelbrock headers and i wanted to know if they would bolt to the stock y pipe that my car has or would i need a new one
Old Feb 12, 2009 | 11:53 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Re: y pipe question
Write the great folks at Summit. They can match some up for you.
Old Feb 13, 2009 | 12:06 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: y pipe question
they can i will do that thank you do you think they are good they have some rust how can i polish them any idea
Old Feb 13, 2009 | 05:33 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: y pipe question
http://www.eastwoodco.com/jump.jsp?i...88&iSubCat=787
Advance sells a different brand that is supposed to be good to 1,400F ~$7.95 a can. It has similar instructions comments as Eastwood site
Old Feb 13, 2009 | 06:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: y pipe question
They won't bolt up--and you really wouldn't want them too since the OE Y is terribly restrictive. Many headers come with a matched Y, which makes life much easier because no fabbing is necessary.
JamesC
Old Feb 13, 2009 | 09:36 AM
Guro 305's Avatar
Axle/Gears: Stock
Re: y pipe question
JamesC
He's right. It's been a longtime since I bought my headers but less time since the y-pipe. I can't recall if my headers were Hedman or Summit brand but the y-pipe is by Flowtech. If you look through Summit's stuff they have several and can tell you the differences between them.
The only thing I can tell you that I had that was a problem was with the bigger thicker aftermarket y-pipe, I had some fittment problems with the cat' and intermediate when it came to the transmission hanger. If I remember correctly I think I had to mod' the hanger somewhat to be able to use that location to hang the cat' from. I just used a couple jacks to kinda push up and slightly bend the pipes to where they were acceptible but I'm not smacking them on speed bumps or anything and my car is lowered so that means I did something right.
Old Feb 13, 2009 | 09:50 AM
JamesC's Avatar
Re: y pipe question
[QUOTE=Guro 305;4042161The only thing I can tell you that I had that was a problem was with the bigger thicker aftermarket y-pipe, I had some fittment problems with the cat' and intermediate when it came to the transmission hanger.[/QUOTE]
Though pricey, the following is a direct-fit three-inch system: Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR). No clearance issues with the above.
No problem using the OE cat-hanger:
https://www.thirdgen.org/forums/exha...ger-fix-p.html
JamesC
Old Feb 13, 2009 | 10:00 AM
Guro 305's Avatar
Axle/Gears: Stock
Re: y pipe question
JamesC
Cool man. Hopefully we gave JR350TPI some good direction.
I remember now. It was your post I had used to redo this. I found a good tranny hanger at the junkyard, put the hanger on a vice and drilled out the rivet. I also drilled a new hole much farther back then the original to mount the rubber hanger farther back to be able to hold the pipe without squishing the hanger.
Old Feb 13, 2009 | 05:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: y pipe question
So i should save up more instead until i have money to buy the headers and the y pipe right it would be much easier that way and would it be cheaper that way
Old Feb 13, 2009 | 05:39 PM
JamesC's Avatar
Re: y pipe question
On the money (cheaper because you won't end up purchasing twice--once to simply have headers, once to replace those with what you should have bought the first time. Ask me how I know ).
JamesC
Old Feb 13, 2009 | 05:47 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: y pipe question
JamesC
what headers do you recommend me with the y pipe
Old Feb 13, 2009 | 05:51 PM
JamesC's Avatar
Re: y pipe question
Replied to in your other thread.
JamesC
Old Feb 14, 2009 | 12:33 AM
Guro 305's Avatar
Axle/Gears: Stock
Re: y pipe question
JamesC
Totally. DIOADIR = Do It Once And Do It Right!!!! This way you won't have to do it again.
I have owned my car for fifteen years now and it's taken me fourteen of them to get it right being a cheap bastard. Don't do it. Save your money and buy the right stuff and you can spend more time cruisin' and less time wrenchin'.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
