What plugs with 2055's?
Old Feb 19, 2009 | 09:04 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Hey everyone, I'm puttin my 2055-1 headers on this Saturday. What plugs should I use? I did some searchin on here and found out that the Autolite racing plugs fit okay. Can u guys give me some sugestions of brand and part#'s. In the post's I read they never gave part#'s. Any suggestions? Thanks.
Old Feb 19, 2009 | 12:18 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: What plugs with 2055's?
Davey, I will put on a set of 2055 soon and read angled plugs are neeeded, but some posted poor remarks about Accel sparks. What wires are you using?
Old Feb 19, 2009 | 01:22 PM
DAVEY420's Avatar
Car: 85 IROC Z
No they will fit heads that use angle head plugs. Yeah I read that the accel suck also. For wires everyone says you just have to have all 90 degree boots. I have 2 sets of wires at home so I'm gonna mix and match until I can afford a nice set.
Old Feb 19, 2009 | 04:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've been using Accel 276S since 2001. No problems with them other than the terminal coming loose. I just took them off and pinched down the outer end so it stays tight on the threads when screwed on.
Old Feb 21, 2009 | 08:38 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Davy, I how did it go w/ the 2055 install?
I'm going to go with the Accel 276S sparks like five7kid suggested. Also, thought it was interesting that the Accel 276S is only one used World Products engines @ http://www.worldcastings.com/faqs.htm (wouldn't one of those beasts under the hood be sweet?)
Old Feb 23, 2009 | 12:36 PM
DAVEY420's Avatar
Car: 85 IROC Z
Everything went good. Install was easy. We didn't even have to unbolt any motor mounts. The car sounds great now.
Old Feb 23, 2009 | 02:08 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
i run the ar133's with 90deg boots, no problems. hedman lt's if this helps at all.
Old Feb 24, 2009 | 07:33 AM
DAVEY420's Avatar
Car: 85 IROC Z
I ended up goin with AR25's with all 90 degree boots. It all fits good. Scooter 500 I would love to have 1 of those engines in my car. One day I will.
Old Feb 24, 2009 | 10:30 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Because I figured headers would improve room near the plugs I have to ask.
I have some ACF-2's, I know I know, platinum sucks but I bought these because I read (on here) many using them without problems, plus I got a deal 8-$8...Anyway will they fit as well? I have MSD 90* boots also.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
