Single Piece Catback
Old Mar 19, 2009 | 11:00 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Ok, so I've finally got all the parts for my entire 3" exhaust. I have a single piece Dynomax Catback, Hooker 2055's and Y pipe, and Catco 3" cat. My question is, has anyone been able to install a single piece catback without dropping the rear end? I know the hooker and flowmaster catbacks are in several pieces you can bolt together. I'd like to do this a home, but I'm unsure if I'll be able to.
Any input would be much appreciated.
Here is a pic:
Old Mar 19, 2009 | 12:01 PM
matj1990's Avatar
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
Re: Single Piece Catback
cut clamp weld i would think your going to have to cut it install it where you want clamp it then weld in place
Old Mar 30, 2009 | 05:43 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
now that is a thing of beauty. what i need is a prefab one in stainless that i can buy. cat to the muffler.
Old Mar 30, 2009 | 06:04 PM
Stephen's Avatar
Car: 87 GTA
Jack the car UP, UP, UP....
Unbolt the rear socks.....
Swing the rear end down....
And you might be able to snake the mid-pipe in from the rear, with the muffler section still attached.
Old Mar 30, 2009 | 07:02 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Yeah, like Stephen said, I think if you can get the car high enough in the rear, it would be possible.
Old Mar 30, 2009 | 07:28 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
you could cut just as it starts to go up in front of axle, then put a stainless easy seal clamp on it . these clamps are made to butt two pipes of same diameter together
Old Mar 30, 2009 | 08:37 PM
Car: 1990
Axle/Gears: stock
both jegs and summit sell them - look pretty good about 15.00.
Old Mar 30, 2009 | 09:17 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You could probably just remove the passenger tire, shock, and spring. Then snake the exhaust in.
Old Mar 30, 2009 | 10:32 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Now thats good thinking! Except the lca and both upper and lower panhard would have to come out to put it in from the side.
Logan Bryant
Sep 18, 2016 09:27 AM
Justins86bird
Sep 27, 2015 09:43 AM
ericjon262
Sep 11, 2015 06:07 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
