Do Headers Actually "ADD" Power?
Old Mar 23, 2009 | 09:22 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Got my 2055s today, can't wait to get them on this week hopefully.
Down to business. What amount of power if any do headers actually add? I know they flow better but would it make a noticable difference on my car? How much on a dyno? My Iroc is an 89 LB9 M5 with 3.08s. Lets "pretend" it has 210 hp now. With all my exhaust done would i be looking at 220+ hp?
Heres how it stands (as soon as my headers are on lol).
Hooker 2055s with the collector opened up.---3" QTP cutout---3" magnaflow
Old Mar 23, 2009 | 09:48 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Do Headers Actually "ADD" Power?
They dont add power, they free up power lol. Definantly a noticable different with headers. Once you take off the stock manifolds and look at them youll see why.
Old Mar 23, 2009 | 09:52 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If they're replacing stock manifolds, yes, it will definitely be a noticeable difference. You'll probably gain more than 10 hp.
Old Mar 23, 2009 | 11:47 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I gained 2mph in the 1/4 mile after my hooker 2055's.
Old Mar 24, 2009 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just some general info that you may find interesting:
I purchased the 350 HO Deluxe based on a review/build up and dyno test in CarCraft (Feb. 04). With iron exhaust manifolds, 2 1/4" exhaust pipes and a pair of turbo mufflers, the HO Deluxe managed 354 lb-ft of torque and 320 hp (which apparently wasn't the way that GM tested). Throwing on Hedman 1 5/8" long tubes, with no other changes, added 23 lb-ft of torque and 17 hp.
JamesC
Old Mar 24, 2009 | 08:16 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have pretty much the same car, replaced stock stuff with 2055's, 3" Cat and 3" exhaust... Actual dyno numbers would be cool... I'm assuming some where between 10 and 20 HP for a complete exhaust, Headers / Cat & Cat Back...
Rafael
Old Mar 24, 2009 | 09:04 AM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
There are a LOT of factors involved to determine how much gain you will see. I have seen as little as 10HP gain up to 32HP gain on a chassis dyno with different combinations.
Here is a SWAG at what you will see depending on what all you do and how much you are changing.
Just headers and stock exhaust = 7 to 10HP
Headers with bolt on exhaust system and cats = 12-20HP
Long tube headers with a calculated size exhaust for your application and a GOOD free flowing (no turbulance) exhaust without cats = 20+ HP
Keep in mind the condition of the exhaust you have now makes a BIG difference in gains you will see. If you have cats now that are old and you remove them you will see a larger improvement. If your mufler is a stock setup and you go to a good flowing muffler you will see more gains.
As mentioned earlier, you are not building HP in the car, you are freeing up what was being restricted by the exhaust system you are replacing. The 32HP gain I was able to get was on a LS1 Camaro with LG headers, 4" single mandrel bent tubes through a high flow cat and single chamber race series flowmaster. It was not a "pretty" exhaust BUT made good power and had a good sound.
Old Mar 24, 2009 | 10:03 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Getting mine soon, woot woot.
Old Mar 24, 2009 | 08:12 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i freed up lots with my 2055s as you know... got my magnaflow cat back today. going on thursday. hopoe that test pipe works out for ya!!!
hectre13
Sep 8, 2015 03:38 PM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
