How many people are running Long Tube headers?
Old Apr 1, 2009 | 07:16 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
I might get a pair with a y-pipe for a LT1 build of mine i know its tight but i think it can be done with not to much crap. I will also be getting the pro kit springs so how low will i be?
thanks
kevin
Old Apr 1, 2009 | 07:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: How many people are running Long Tube headers?
ground clearance will be low low..
my LT's with a custom Y 2.5" y pipe at the lowest point is 1.7" off the ground. and that lowest point is tucked up as well as it can without having rattling problems.
Old Apr 1, 2009 | 07:54 PM
Is your car lowerd any?
kevin
Old Apr 1, 2009 | 08:43 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
His car must be lowered. I am at stock ride height, and I have duals with my long tubes and I have NEVER scraped the ground, at all. With the right manual transmission, or if I could just raise the transmission crossmember on the passenger side, I could probably gain at least 1" more of ground clearance. 1.7" seems really bad... now I want to measure my ground clearance.
Old Apr 1, 2009 | 08:46 PM
Ok i know its tight and not the best for lowered camaros but i think it will be fine if you take it real slow over speed bumps and stuff.
kevin
Old Apr 1, 2009 | 09:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i have sportlines and the front spring spacers are gone.
driving is fine, i cant take speed bumps at all, and i have to be careful on rough roads, but besides that its ok, oh, this isnt a daily driver by any means (see sig) so I dont mind it so much.
Old Apr 1, 2009 | 09:24 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
I have a set and speed bumps are a pain. i would say somewhere around 3"-4" of clearance
Old Apr 1, 2009 | 09:28 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
GoodlookinRS, is your car lowered?
Old Apr 2, 2009 | 12:42 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
im running hedman 1-5/8" long tubes setup
they actually fit really well for long tubes...they dont hang too low either
i will be switching back to my hedman shorties as soon as my part car sells
Old Apr 2, 2009 | 12:55 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Toyota h8r, why would you put short tube headers on if the long tube headers fit so well?
Old Apr 2, 2009 | 01:26 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
the exhaust on my parts car is 100% brand new lol.....
my friend GAVE me a whole exhaust setup consisting of hedman long tubes with "custom" y-pipe to a flowmaster 80 series muffler. its all 3" and massive 4" chrome tips...which looks HORRIBLE on a 91 trans am
i love my edlebrock setup on my parts car....the fit and finish of hedman headers and the catback from edlebrock is the best IMHO.
it uses a slash tip design that hides under the car.....like stock setups did
Old Apr 2, 2009 | 02:31 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
That's a good reason...
Old Apr 2, 2009 | 04:03 PM
My car is stock height right now but i will be doing the pro kit and koni yellows. After my LT1 build though.
kevin
Old Apr 2, 2009 | 04:12 PM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
im putting mine on next weekend hopefully,hedman longtubes. im at stock height,or maybe little higher since ive removed bout 80 pounds from under the hood.
im running LTs to 2.5in xpipe to turbo mufflers with turndowns before the axle....same setup my friend has on his 01 T/A....well aside from him having a 3in xpipe and a 3in drop.
Old Apr 6, 2009 | 02:39 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
I have this setup as well. single 4" all the way back from them, 1.5" lowest clearance for me. Car's lowered, cut the coils a bit.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
