header install questions
Old Apr 19, 2009 | 10:00 AM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Im trying to install my new headers (2055) on my 305 and have a few questions.
1. how do you reuse the alternator support
2. what is the sensor under the passenger side header (on the block)? it seems to be broken
thanks in advance
Old Apr 19, 2009 | 10:13 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: header install questions
need a little more information. what kind of headers? what kind of block - engine. headers with air injection. a little help here.
Old Apr 19, 2009 | 10:18 AM
TheMuskr's Avatar
sorry i was in a rush they are hooker 2055 and its a 305. with air injection
Old Apr 19, 2009 | 11:11 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
for the alt. & A/C support i used stock bolts for the brackets , along with a stack of 3/8" washers . next day picked up some 3/8" id s/s tube , cut to length , replaced washers , looks good . good luck .
Old Apr 19, 2009 | 11:27 AM
TheMuskr's Avatar
thanks for the quick response but when i try to put the stock bolt in on the alt side the header gets in the way. i was thinking of shortening it a bit maybe
Old Apr 19, 2009 | 11:34 AM
UNCLE TOM's Avatar
forgot you asked about broken sensor . if it's between the 2 rear plugs it's the fan switch . you should have a single lead wire hanging some place below . easy/cheap to replace . good luck .
Old Apr 19, 2009 | 11:51 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Just wondering if that part has a lever attached to it? Wondering what it is and if I will need when i put my headers in. Sorry to interrupt the conversation
Old Apr 19, 2009 | 11:53 AM
TheMuskr's Avatar
ok good to know what it is. so i assume the fans wont turn on without it? and i was also wondering what cheaper plug wires would work?
sorry lots of questions
Old Apr 19, 2009 | 12:03 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
coolant temp sensor if you mean in the back (at least on my tbi) and I could not reuse my support.
Old Apr 19, 2009 | 01:42 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Hey fellow Minnesotan! Reading the thread "those with hooker 2055s come on in" should help greatly. Here's what i did for my install. (of 2055s)
Once i got all the old junk off, including the dipstick, i shoved paper towels in the exhaust ports. then i took some 400 grit sandpaper and smoothed the heads real nice. BE SURE TO CLEAN ALL THREADS VERY GOOD!!! the old manifold on the pass side uses a different bolt hole then the headers, so the hole that the header bolt goes into was full of crap. Once you got everything cleaned up go ahead and put your headers in and bolt them tight going from the center to the out side. I did not use the alternator support nor the a/c compressor support. I really dont see how the alt. or a/c will move without the extra brackets. The sensor on the pass side head is for your fans, the one on the drivers side is the temp gauge (IIRC). Just read through that thread i told you about, most all your questions will be answered
Old Apr 19, 2009 | 02:13 PM
TheMuskr's Avatar
thaks sooo much. love to see minnesotans on here! i was thinking of ditching the alt brace. only problem i have now it getting a plug wrench on the plugs twords the rear. any tips?
Old Apr 19, 2009 | 06:05 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Of course theres a tip for that! I learned this on here aswell, soo much info on this site its crazy.
Take your common spark plug socket, and cut about a 1" x .5" slot down the side of it. This modified socket allows you to put it on the plug sideways to clear the header, then you just slide it on the rest of the way and tighten.
Old Apr 19, 2009 | 08:22 PM
TheMuskr's Avatar
wow good idea. well i have everything bolted up just need to get the cat off the old y pipe . this should be fun haha
Old Apr 23, 2009 | 09:07 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
if you have any other ?'s just ask. for plug wires i would say at least 8mm and make sure they are all 90* boots. as long as you keep them out of the way you should be fine.
Old Apr 24, 2009 | 08:20 AM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
If the sensor is in the head, its for the fans....if its the one in the blockthan its the knock sensor. A bad fan switch should run the fans all the time when the key is on. The purpose of the braces are to take stress off the main brackets....without them you will probably at sometime have bolts and/or brackets breaking. Very common on the pickups, very similar serp belt setups.
Old Apr 24, 2009 | 10:42 AM
Pocket's Avatar
Car: 91 Trans Am
The heads should come with a bag of hardware including the sleeves to reuse the braces. These reused the factory manifold bolts
Drivers is hard to see
Clear view of the spacers on the pass side
For plugs, get some Accel header plugs, they are about 1/2" shorter
Tool, hacksaw 1/2" off a cheap sparkplug socket and use a wrench on the back of it. You shouldnt have to slot it, but it wont hurt if you do
Wires: 90 Chevy 1500 truck wires. If you get the premium set they are 8mm
One wire will be a few inches too long, just tuck it behind the distributor. All others are perfect length and 90* boots
Old Apr 28, 2009 | 05:05 PM
TheMuskr's Avatar
ok great thanks guys. i got all the braces back on. i feel much better now that they are. also got new plug wires with 90* boots. i now have (kinda have always) a small rough idle. anything that i could look at to smooth it out.
Old Apr 28, 2009 | 06:05 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Make sure your wires are all on right. When i put my headers on and cured the coating i used a laser thermometer and 2 cylinders where only 80* lol. switched the wires and it was 500*
Old Apr 28, 2009 | 07:23 PM
TheMuskr's Avatar
took them off one at a time so i should be alright. hopefully
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
drathaar907
Aug 6, 2015 04:20 PM
