2055 gaskets
Old May 12, 2009 | 12:35 AM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
2055 gaskets
First I ordered the Percy's deadsoft gaskets but I didn't not know #1 that the hooker port was squarish and the percy's gaskets were round port. So I sent back the round port percy gaskets and exchanged them for the square port gaskets, now I was comparing the square percy's gaskets that just arrived today to the gaskets that came with the 2055's and the percy gaskets are a bit larger, 1.5 in size. What woudl you guys recommend doing? Will the oversized square port percy gaskets fit? Or should I just use the ones provided with the 2055's?
Thanks in advance for any help.
Old May 16, 2009 | 01:09 AM
tdavolos's Avatar
Car: 87 GTA
Re: 2055 gaskets
Im sticking with the ones that came with my 2055's. If your like me and have your head under the hood constantly, checking the header bolts once or twice a week shouldnt be a problem.
Old May 16, 2009 | 11:33 AM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: 2055 gaskets
Well that won't be a problem either because i also got the stage 8 locking bolts, but I just wanted to be completely assured (peace of mind) and go with the dead soft ones too, but i think i'll just use the gaskets provided, thank you for your help.
Old May 17, 2009 | 07:26 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: 2055 gaskets
be sure to post and tell us how those locking bolts worked out. i will be installing mine soon so im asking everyone what they thought worked best.
for 50.00 they should put themselves on and give you a big wet sloppy kiss too.
Old May 26, 2009 | 11:48 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: 2055 gaskets
The gaskets that come with the 2055's are crap.
I did a good job of torqueing and re-torqueing during installation and they still failed after 2K mi. I suspect that Hooker (Holley now) knows this... They have an interest in selling after market header gaskets.
I'm installing Percy's Aluminum gaskets now. The round hole ones.
Stage 8 bolts are nice.
Old May 26, 2009 | 06:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
One of my "nits" about the 2055's.
Just lay them over the headers and you'll see they are smaller than the header ports. They were also smaller than the as-cast ports on my World 305 heads. I asked Holley about that, their answer was "The heat from the exhaust gasses will soon burn away the excess gasket material." Not exactly confidence-inspiring.
I used Fel Pro gaskets. Forget the number, standard off-the-shelf stuff. Never have had a problem with them.
Old May 26, 2009 | 06:32 PM
Car: 1990
Axle/Gears: stock
Re: 2055 gaskets
good to know -i have not even opened the package the gaskets came in.
Old May 26, 2009 | 06:57 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: 2055 gaskets
i've not had a prob with the hooker gaskets or the stage 8 bolts. had them both on the car for around 2 months now and drive it everyday. let us know how your install goes.
Old May 26, 2009 | 07:34 PM
Car: 1990
Axle/Gears: stock
Re: 2055 gaskets
will do but i will have to build out the heads first - then install everytthing at one time. tpi, cam, heads, headers.
Old May 26, 2009 | 11:34 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: 2055 gaskets
I had mine on for four years with no leaks. I purchased FelPro header gaskets and they fit my 2055's and AFR heads perfect.
Old May 27, 2009 | 01:40 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Re: 2055 gaskets
The Hooker supplied stock gaskets are an aluminum sheet with another layer of some type of composite on each side. On the set that I just removed, the layer on each side is toast...brittle, fried, cracked, missing.... crap, after only 2K miles! My advice is DO NOT INSTALL THESE GASKETS!!! I have much regret after doing so...
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
