stock y pipe replacement?
Old May 21, 2009 | 11:26 AM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
i need a new y pipe for my 87 ta, stock manifold, 5.7 700r.
where can i find a replacement y pipe?
mine has a couple of seam splits, and needs replaced,and not ready for headers yet.thanks.
Old May 21, 2009 | 11:46 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: stock y pipe replacement?
If it's in good shape other than the split seams,you might have better luck having it welded.
Old May 21, 2009 | 12:40 PM
TransAM Joe's Avatar
http://www.macperformance.com/store/...Product_ID=450
Direct replacement, much better than stock y pipe.
Old May 22, 2009 | 09:13 PM
Engine: 350TPI
Transmission: AUTO
thanks, that looks like what i need.
Old May 23, 2009 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Make sure it's in stock before you order. Seems I recall that there was a problem a while ago.
JamesC
Old May 28, 2009 | 11:57 AM
Engine: 350TPI
Transmission: AUTO
yes james, they do not have one, dont know when they will have any, or any shipping dates,
sooo, ive ordered one from jegs, looks to be the same, ships today,hope this works.
Old May 29, 2009 | 06:56 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
reset computer after exhaust?
Does the computer need to relearn after exhaust install?
In Feb had a magnaflow cat-back installed. Car did not move miles since mid may. Then I had a new Y-pie put in a cats cut out.
Car is slower now--have drag raced to confirm this. I figure it can be the exhaust or it can't be---but thought the computer might be possibility.
thanks
Old Jun 1, 2009 | 09:26 PM
Engine: 350TPI
Transmission: AUTO
got the y pipe in from jegs, looks good, and the fitment is very good.
Attached Thumbnails stock y pipe replacement?-pipes-001.jpg   stock y pipe replacement?-pipes-005.jpg
Old Jun 11, 2009 | 09:16 PM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
What is the part number on this y-pipe. nad is that a cat delete pipe you ordered or made?? If ordered from where and part number please.
Old Jun 11, 2009 | 09:33 PM
Engine: 350TPI
Transmission: AUTO
http://www.jegs.com/i/JEGS/555/31050/10002/-1jegs #555-31050 the catpipe is included, i used it, as my converter was hollowed out anyway by the former owner.the fitment is very good.
Old Jun 11, 2009 | 09:50 PM
Miles87Z28's Avatar
Thank man. I really need a new y-pipe. mines full of leaks.
Old Jun 11, 2009 | 11:40 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Would a V8 y-pipe fit a V6? I know the rest of the exhaust does....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
marcusaw
Aug 10, 2015 08:13 AM
